Did you know? 🤔
How many drain and fills ?
2001 - 2007 XC-70
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 69 times
Been thanked: 12 times
United States of America
GlennG2759
Post by GlennG2759 » Fri Aug 02, 2019 5:21 pm
2006 V70 NA new to me 100,500 miles. Vehicle shifts fine.Trying to do the math. How many drain and fills do I have to do to get to relatively fresh fluid. First took 3.5 qts.(very dark). What is the recommended mileage in between drain and fills? Thanks
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 28 times
MDK
Re: How many drain and fills ?
Post by MDK » Fri Aug 02, 2019 5:27 pm
I'd get 11 more quarts.. 3.5x3.. then get a bottle of lubegaurd .. add 5 oz(1/2 bottle) on the final one. I personally pumped mine out @the radiator. 2002 V70 non turbo 215,000 miles..
These users thanked the author MDK for the post:
GlennG2759
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 34 times
Been thanked: 70 times
MoVolvos
Post by MoVolvos » Fri Aug 02, 2019 6:10 pm
There are some who fear changing the fluid all at once regardless of method
This is what you are considering doing. Some however do this over a period of weeks between each.
Many here just do it all at once.
These users thanked the author MoVolvos for the post:
GlennG2759
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
xtwister
Year and Model: 2001 Volvo V70 T5
Has thanked: 0
Canada
xtwister
Post by xtwister » Fri Aug 02, 2019 6:40 pm
I did 2 drain and refills and put transtune in. I did have major shift problems but now it shifts gears like new.
These users thanked the author xtwister for the post:
GlennG2759
Has thanked: 0
Been thanked: 133 times
Post by cn90 » Fri Aug 02, 2019 7:16 pm
Check to be sure but total fill from factory (from a dry system) is about 8.1 quarts.
For a simply drain and refill, it is about 3.5 quarts.
Just use the principle of "half-life" or dilution ratio and do the math.
I wrote a DIY ATF fluid for XC90 a while ago...
viewtopic.php?f=10&p=514720
SuperHerman
Has thanked: 0
Been thanked: 158 times
SuperHerman
Post by SuperHerman » Fri Aug 02, 2019 9:02 pm
Were it me I would do a drain and fill, drive it for a day or two and then do another drain and fill. After that just do a drain and fill every two or three oil changes.
These users thanked the author SuperHerman for the post:
GlennG2759
daughtersmechanic
Year and Model: 2001 V70 XC
Has thanked: 5 times
Been thanked: 0
daughtersmechanic
Post by daughtersmechanic » Mon Aug 05, 2019 11:30 am
According to my math, 4 changes will get you to 90% new fluid.
1-- 43.75%
2-- 68.35%
3-- 82.20%
4-- 89.98%
This assumes that the new fluid is fully mixed in with the old.
Of course, after the second drain, you're replacing more new fluid than old, so factor that in to your 'is it worth it?' calculation.
You're a clean freak, you say? You want 99% new? That'll take 8 changes (98.9977%) :P
2001 XC70, The Beast, 222K
BlackBart
Has thanked: 76 times
Been thanked: 56 times
Sweden
BlackBart
Post by BlackBart » Mon Aug 05, 2019 1:24 pm
MoVolvos wrote: ↑
Is this the same as the "Gibbons Method" I've read about?
What are general opinions on the need for the in-line filter that he added?
1994 850T wagon
Is it time for a 1964 122 wagon?
MoVolvos
MoVolvos
Post by MoVolvos » Mon Aug 05, 2019 2:04 pm
BlackBart wrote: ↑
MoVolvos wrote: ↑
I think if I were to put in a filter I would install a "Y" so it is only filtering a portion. Not sure how much the filter reduces the pressure or if there were ever a major issue with the transmission it would be plugged up?
I purchased quite of few of the Magnefine filters years ago during a sale but never got around to installing them. One was for a 98 S70 T5 which seem to get dirty pretty quickly.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Has thanked: 333 times
Been thanked: 1035 times
Trinidad & Tobago
Post by abscate » Mon Aug 05, 2019 2:15 pm
BlackBart wrote: ↑
MoVolvos wrote: ↑
Ive tried Gibbons and they just don't get the work done on time..
Screen Shot 2019-08-05 at 4.14.34 PM.png (289.07 KiB) Viewed 164 times
Link To Volvo Glossary
