Did you know? 🤔
How many drain and fills ?
2001 - 2007 XC-70
Has thanked: 72 times
Been thanked: 235 times
United States of America
Re: How many drain and fills ?
Post by erikv11 » Tue Aug 06, 2019 10:29 pm
daughtersmechanic wrote: ↑
Tue Aug 06, 2019 10:09 am
... How does one dispose of used ATF, anyway? The last time I brought oil in for recycling, they put me through an interrogation, afraid that I might contaminate their (already contaminated) oil with some other fluid.
Autozone is happy to take ATF mixed with oil (or not mixed), e.g. https://www.autozone.com/landing/page.j ... onsibility
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 160k
oragex
Year and Model: S60 2003
Has thanked: 92 times
Been thanked: 224 times
Canada
oragex
Post by oragex » Wed Aug 07, 2019 4:00 am
Did flush mine at 100k too. I have to say, it worked less well afterwards. Before the flush it was shifting with only a very small kick, after the flush the kick was more obvious.
The transmission adapts continuously to the fluid properties. Replacing a large part of the fluid at once, may not help the transmission to adapt quickly enough (bigger the change, bigger the adaptation). When we drain the sump, we remove 3.5L which is exactly half the capacity of the transmission. So the transmission has to adapt to 50% new fluid all of a sudden - this new fluid has quite different properties than the old one. Plus, the old fluid is the genuine one, replacement ones (Mobil, Toyota, etc) have different properties. On top of this, the solenoids are old and work more or less freely, so the adaptation is even more difficult.
If I was to do it again, I would remove a smaller amount of fluid every time: more like 2L instead of a complete 3.5L sump drain. Then drive the car at least 500-1000 miles inside the city where the transmission has to do a lot of shifting so has plenty of time to adapt to the amount of fresh fluid. And given the aftermarket fluids are not exactly as the genuine one, I would invest a little and buy genuine fluid. If you look at the cost, 12L of genuine vs 12L of Idemitsu is only $100 more, basically the equivalent of 3 oil changes. I think it's well worth an extra $100 for the transmission. Of course, just my opinion 8)
Rattnalle
Has thanked: 17 times
Been thanked: 119 times
Sweden
Rattnalle
Post by Rattnalle » Wed Aug 07, 2019 6:40 am
Re oil burner.
It says nothing on there about the treatment of hazardous emissions. I think you'd be sued all over if you tried using one of those here and just vented the exhausts.
Has thanked: 246 times
Been thanked: 801 times
Trinidad & Tobago
Post by abscate » Wed Aug 07, 2019 8:21 am
- Pete - wrote: ↑
Tue Aug 06, 2019 6:20 pm
Oh sure, UL listed & everything. Course, lots of DIY type heaters being used. But in the event of a fire you're in deep doo-doo. Or at the least your losses aren't covered.
The one shop I bring used oil/ATF to runs one of these. Last winter, a particularly long, hard & cold one, the guy that owns the shop said he ran through 2,500 gallons.
5 months of heating that is 500 gallons a month, or 3 oil changes a day. Not to mention you still charge the $5 waste disposal fee.
A man after my heart, surely.
Link To Volvo Glossary
BlackBart
Has thanked: 52 times
Been thanked: 37 times
Sweden
BlackBart
Post by BlackBart » Wed Aug 07, 2019 2:42 pm
Rattnalle wrote: ↑
Re oil burner.
And we thought "clean coal" was bad!
1994 850T wagon
Is it time for a 1964 122 wagon?
okidiver
Year and Model: 2015 V60 2008 C30
Has thanked: 7 times
Been thanked: 3 times
okidiver
Post by okidiver » Wed Aug 07, 2019 7:35 pm
That screen shot is the Baboon Method...
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 26 times
Been thanked: 49 times
MoVolvos
Post by MoVolvos » Wed Aug 07, 2019 8:15 pm
okidiver wrote: ↑
In 2nd grade we took a field trip to the zoo. Teased a monkey and it went ape poop :twisted: on my sweater by jumping into the fence from afar. Good thing I had a shirt underneath. Trust me, never monkey around with the Baboon Method.
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Trinidad & Tobago
Post by abscate » Thu Aug 08, 2019 3:07 am
Howler Monkeys. When a predator gets close they throw scat at it.
Gotta respect that, sort of like the work world.
Georgeandkira
Year and Model: 2007 V70 base
Has thanked: 16 times
Been thanked: 43 times
Georgeandkira
Post by Georgeandkira » Thu Aug 08, 2019 8:42 am
HISTORY:
1) Over 3 V70's I've done drain & fills and one pump out aka Gibbons with no ill effects.
.....I've used Toyota T-IV, Mobil3309, Maxlife Dex/Merc LV and a Wolf's Head Universal ATF.
.....I add LubeGard (red bottle) at the recommended 1 oz. per system quart dosage.
2) Doing a drain & fill immediately before a pump out lessens the amount of fluid needed by quite a bit.
3) Many prefer using genuine Volvo fluid. Many others warn against "multi fluids". Make your own decision.
4) One bloke bemoaned the inavailability here of the 20l Mannol keg from Germany. This is where I come in on my white horse.
5) The Amalie store website is down for revision. A company rep sent me this link as I need some fluid now.
Go here: www.amazon.com/Wolfs-Head-836-92866-56- ... ems&sr=1-5
If my fluid was brown, dark brown, black or burned smelling I'd happily perform one or more drain & fills using one of the above fluids.
The degree of clarity you settle for is up to you.
Anyone in the "Volvo trannie fluid only" camp can now use it much more economically.
I ain't washing my dirty beer glass with champaign.
All the pieces I've read on neglected transmissions state that the torque converter collects dirt and that a complete pump out can be soon fouled as said dirt goes into solution.
These users thanked the author Georgeandkira for the post:
GlennG2759
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 58 times
Been thanked: 8 times
GlennG2759
Post by GlennG2759 » Thu Aug 08, 2019 8:52 am
At $17.57 for Valvoline Maxlife full synthetic 4 quart jug at Walmart (my local store parts wants $28.99). I'll do 3 drain & fills over the 500 miles, adding some TransTune on the last one and be done with it for under $70.00. Thanks for input. Glenn
