Water leaking in upper driver's side corner
Houandrew
Year and Model: 1995 850
Post by Houandrew »
When it rains heavily water is leaking in the corner right about the driver’s side where the headliner meets the windshield. Windshield was replaced many years ago and mechanic said it looked as though it wasn’t sealed properly. However the wetness is traveling toward the back of the car. I noticed on the outside above that area under the metal the black “weather strip” is loose. Could the water be coming in from there? Also i put silicon Which i have read is bad in the corner of the windshield from the outside and it still leaks. Please help!
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Does it have a sunroof?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Are you sure that's where it's coming in? Or does it look like it's trailing from somewhere else (like the sunroof)? The sunroof drains get clogged pretty often, and it's possible that water is getting into the car through there.
Houandrew
Post by Houandrew »
I haven’t done a sunroof test. But on the outside of the car on the edge the length of the cars is a strip. The rubber toward the front on the outside of the car is broke near where the leak appears inside. I ran water over that and it got wet inside. Hard to believe that that would be the only thing that originally kept water out. How can i seal that properly? Nervous about using silicon? Any ideas. Or can that entire stripping mechanism have to be replaced?
Has thanked: 1609 times
Been thanked: 4065 times
I’m not getting the visual, a picture or two would replace 2000 words
Post by erikv11 »
Sunroof is well known to leak there, especially if the sunroof drains are clogged, just FYI.
There are some clips that hold that strip onto the roof. The clips screw into holes that are normally sealed up with silicone, that may be the problem. If you want to re-seal under the strips you can just carefully pull up the strip starting at the windshield end, it will unsnap. Check the clips that it snaps into. When you are done, push the strips back into the clips. Work carefully if you do this, you don't want to ruin the strips.
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
erikv11 wrote: 04 Aug 2019, 21:58 ........................ Work carefully if you do this, you don't want to ruin the strips.
FYI
Those strips are very thin aluminum and will kink from normal handling if you lift anywhere but at the clip. Use a flat plastic tool to lift it out of the clip so you don't have to do it from inches away, which will cause it to buckle.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
