AC Not Working
eamonnpetty
- Year and Model: 2009 Volvo S60 2.5t
I drive a 09 s60 2.5t and normally the AC works just fine. It was working perfectly one day while I was driving at work but then later that night I got in the car to drive my girlfriend home and I was getting no air coming out of the vents. Any ideas on whats wrong with it?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Do you get air through the vents with the A/C off ? Did the car battery run flat ?
eamonnpetty
I’m getting absolutely no air what so ever. The car is running fine. Just no ac or heat. I was thinking to just add some refrigerant but I’m not sure if that would fix the problem because it seems as if it’s only the fans that aren’t working.
- oragex
That's not an A/C problem. Do you hear the cabin blower making noise at higher speeds (when turning the knob) ?
If it's dead quiet, the blower doesn't work. Either look for the fuse, for the controller, or for the entire blower unit
If you can hear the blower forcing but no air, it's a problem with the CCM climate control module, may need looked at with the Vida software
- 2014 Views
Last post by Ozark Lee
- 1999 Views
Last post by EngineeringBloke
- 882 Views
- 2556 Views
Last post by oaktown
- 730 Views
Last post by JDS60R
