01 V70 coolcant requirement and recommendation Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I have to replace the radiator, if not the AC condensor with it. Front end fell in a hole; Condensor caved in a good bit and radiator plastic cracked. During my search on forums what coolant to use, my head started spinning. Lots were saying Peak was good, Zerex is good, Prestone is good, phosphate this, silicate that, HOAT (supposedly the type Volvo uses). I read an article that OAT can be more harmful but then another say its better than IAT. RobertDIY (for those with P80, P2 cars) recommended Zerex. Theres pink, red, dark blue, light green, mid to dark green. NAPA has a sale on their universal coolant right now, its the green (silicate right?). Please help me. Should i buy HOAT? I'm looking for a good but cheaper product. I would like some simple answers if thats possible. Thank you.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- CIK7
Thank you. Where do i buy the Volvo stuff from? Is there somewhere else other than the dealer to get it?kranz wrote: 07 Aug 2019, 11:23 Don't get creative. Simplify your life. Sleep well at night. Go get the official VOLVO stuff.
- CIK7
Something i forgot to mention is that the coolant in my system is yellowish (pic attached) and came that way from the used car dealer. The stuff Volvo currently lists as factory for their cars (including the fitment calculator) says blue (G48).kranz wrote: 07 Aug 2019, 11:23 Don't get creative. Simplify your life. Sleep well at night. Go get the official VOLVO stuff.
- CIK7
Is this accurate? This is what i found. Theres the Valvoline brand Zerex G48, then theres Volvo OEM G48.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, really don't see the idea with Zerex. Stay away from Prestone, I had it and it caused deposits.
Volvo coolant concentrate sells for $25, mixed with 1 gallon of distilled water from Walmart ($2), it's under $30. Prestone you have to buy the 50/50 it gets even more expensive. Zerex concentrate is about same price as genuine
https://www.fcpeuro.com/products/volvo- ... vo-9434699
Get a small paper towel and dip it in the reservoir, sometimes it appears yellow but once outside may look green-ish. If in doubt, flush the system a few times with distilled water (fill, drive, flush, repeat). Never put the garden hose in there - never use tap water because it cannot be fully flushed and will cause limestone deposits that can block passages
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Zerex G-05 is the correct alternative to Volvo coolant. It is yellow, just like what appears to be in your reservoir. Usually runs around $17-18/gallon. The prediluted & full concentration bottles are easily mistaken, so just be sure of what you have before you dump it in.
Edit: Iβve usually paid $17-18/gallon of concentrated G-05, but I see it is available online for less than $15 for full concentration.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
Oragex,oragex wrote: 07 Aug 2019, 12:00 As above, really don't see the idea with Zerex. Stay away from Prestone, I had it and it caused deposits.
I emphasized your first sentence. What did you mean by this?
Did you mean you don't trust the brand Zerex in general? That particular formulation (G48)?
Or is it just the fact that it's about the same price as genuine? etc.
Just curious.
I have been using Zerex G05 without issues in my 99 for a few years now and I just wanted clarification on your first sentence.
Thanks
-A
- 19 Replies
- 40948 Views
Last post by Jdawgvolvo
- 1372 Views
Last post by CIK7
- 12 Replies
- 2566 Views
- 1230 Views
Last post by raybythelake
- 2889 Views
Last post by erikv11
