I need to replace the leak detection pump on my 07 volvo s40 and can't not find it's location on the vehicle.
Can someone help me locate it please
leak detection pump location
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
What is a leak detection pump?
gwahlenberg
- Year and Model: 2007 S40
code P2402 evaporative emission system leak detection pump control circuit high
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
It's probably just a pump, and the error message is 'leak detection'
- RickHaleParker
- Been thanked: 977 times
Think leak down test for the Evap system.
Active
Past
Past
- MoVolvos
Thanks, I googled it to see what it looks like.
So this pump is for the sole-purpose of self-diagnostic of the Evap System?
Is it creating pressure at all times?
- MoVolvos
Not sure if you found it?gwahlenberg wrote: 08 Aug 2019, 07:48 code P2402 evaporative emission system leak detection pump control circuit high
GR-372945 - Same parts diagram for both the 2.4 & 2.5. Part #8. I'm not familiar with the Evap System so I could tell either way its location.
https://www.volvopartswebstore.com/show ... evel=24658
- MoVolvos
Thanks.Cees Klumper wrote: 12 Aug 2019, 00:05 It's probably just a pump, and the error message is 'leak detection'
gwahlenberg
I found it. It is in a very hard place to get to. The bracket that holds it in place seems to be welded to the frame of the car. I was barely able to take the screws off. Now having hard time trying to take part off. I even tried to bend the bracket but it is not going anywhere... This car is a pain.
Cees Klumper
Sometimes people loosen engine mounts and jack up / tilt the engine, or remove other components, just to get better access, not sure that would help in this situation.
