Did you know? 🤔
RPM/Shift flares Topic is solved
2001 - 2007 XC-70
Nathan79
Year and Model: 07 XC70
Has thanked: 0
Been thanked: 4 times
United States of America
Nathan79
RPM/Shift flares
Post by Nathan79 » Fri Aug 09, 2019 8:27 am
Daily Driver 07 Xc70, 175k symptoms: Driving (keeping rpms under 2500) shifts wonderful, zero issues.
However when getting RPM'S get between 2500/3000 there is a RPM flare, & if Throttle maintains its position the RPM flare will repeat until throttle position is changed... Somewhere in the neighborhood of 300-1000 RPMs flare
When driving (from a stop or already cruising doesn't matter) and throttle is "pressed with conviction" and RPMS get to 3000-3500 before shifting...sounds rowdy and I'm off to the races.
No codes ever... Been driving it this way for about 10k miles...Not getting worse OR better.
Also worth mentioning...ABS module is out, no brake power boost, odometer not functioning (but will momentarily show that its working upon startup sometimes)
Things I've done so far(after symptoms started): tranny fluid flush & b4 servo piston swap. *Charging system tested good... However I'm not sure if it was tested under 3000 rpm load.
Thanks for any help
Nathan
SuperHerman
Has thanked: 0
Been thanked: 128 times
SuperHerman
Re: RPM/Shift flares
Post by SuperHerman » Fri Aug 09, 2019 9:27 am
Try taking a look at the throttle boy. Maybe give it a cleaning.
oragex
Year and Model: S60 2003
Has thanked: 92 times
Been thanked: 226 times
Canada
oragex
Post by oragex » Fri Aug 09, 2019 3:09 pm
I've read on a website with reviews that the throttle body on these late 2007-2009 S60 may have problems (not the same as early 01-02)
Not saying is sure. Maybe ask Xemodex guys, see if they are aware of such issues.
If you go that way, maybe try getting a used one from the junk yard - not sure about programming/compatibility
Nathan79
Has thanked: 0
Nathan79
Re: RPM/Shift flares  Topic is solved
Post by Nathan79 » Mon Aug 12, 2019 12:41 pm
Thanks for the time & thought! I will pursue ETM...
Nathan79
Has thanked: 0
Nathan79
Post by Nathan79 » Tue Aug 27, 2019 6:11 pm
So...what had happened was, about a week ago I went to leave for work after firing & warming up, but pedal was NOT responsive. Figured that it was the ETM, so ordered remaned OEM for about $100... Installed,without any flash and we're back to business
Nathan79
Has thanked: 0
Nathan79
Post by Nathan79 » Thu Dec 19, 2019 7:31 am
A follow up... So, yes the ETM failed. But I believe the REAL source of the problem to have been a "thrashed" intake pipe. Even after the ETM replacement there was still "surging" happening @ about 2700 rpms. Once I replaced intake with an upgraded Snaab pipe 😉... ZERO RPM flares.
FYI... Intake pipe was heavily cracked @ turbo connection site.
Fun fun fun
These users thanked the author Nathan79 for the post:
Has thanked: 248 times
Been thanked: 807 times
Trinidad & Tobago
Post by abscate » Thu Dec 19, 2019 7:34 am
Thanks for follow up Nathan...it’s typical to have more than one thing wrong. I wonder if the leak in the pipe was fluttering the throttle body and led to early failure. Pure speculation on my part.
Link To Volvo Glossary
Nathan79
Has thanked: 0
Nathan79
Post by Nathan79 » Thu Dec 19, 2019 9:06 am
My thoughts exactly abscate. Makes sense at least. As usual... You guys on here ROCK!! I'm on here more often than I'd like to be, but who knows where I'd be WITHOUT you guys... Thank you so much for keeping us Volvo lovers...well...loving our volvos!!
