I'm having trouble with the climate fan in my 2002 V70. It's intermittent. Sometimes it blows in pulses. wooh, wooh, wooh, maybe about 1-2 Hz. When the car is really hot, when it's been parked outside and baked in the sun, (interior well over 100F,) then it doesn't blow at all. (Most inconvenient, the blower fan dies when you need the AC the most!) The blower fan varies when the setpoint is manual, set to a constant speed. The fan doesn't make any noise, and seems to run quite properly when thing are cool.
Any suggestions on the problem? The motor seems fine. The controller (even when in manual, at a fixed setpoint) is ignored. Any suggestions on how to troubleshoot and confirm vs. just randomly replacing parts?
Thanks for the suggestions!
Roger
V70 Fan Intermittent
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
What do you mean by ignored controller ? The other thing to look at is the cabin temp sensor
- Roger_850T
By that I mean I can set the manual fan control somewhere (middle, max, off, anywhere in between) and the LED's around the knob light up in the corresponding position (middle, max, off, in-between), but the fan does not change at all.
When the fan chooses to run, it sounds great. (No grinding or ugly bearing noises - sounds like a properly running fan.) And when it's working properly, then adjusting the manual control knob makes the fan speed up and slow down accordingly. But when it's misbehaving, it blows in pulses, "wuh wuh wuh" or doesn't run at all. When it's pulsing, it still sounds good, (no other unusual noises then, either,) just gives erratic airflow.
Roger
11 XC60 137k
05 XC90 V8 213k
05 XC90 V8 213k
- Roger_850T
Also, when the fan is not running, if I turn the manual knob, I see the green light for the A/C turn amber when the fan knob is at zero, then green when the fan is supposed to be turning. I have not been successful in inducing airflow by driving with the windows cracked open, so I don't even get any cooling at that point.
The worst is when the wife parks it in a sunny parking lot while she's shopping, then the A/C doesn't work when she gets back in the car. I really feel the heat on that one...
Roger
Roger
11 XC60 137k
05 XC90 V8 213k
05 XC90 V8 213k
- 1451 Views
- 1881 Views
Last post by alschnertz
- 3982 Views
Last post by englemancr
- 1895 Views
Last post by JeffHicks
- 11 Replies
- 2038 Views
Last post by rick4484
