Did you know? 🤔
91 240 wagon crossmember bolt holes
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
e777
Year and Model:
Has thanked: 1 time
Been thanked: 0
e777
Post by e777 » Sun Aug 11, 2019 7:43 am
Hello,
So, after having removed the crossmember to replace the transmission mount, I am putting everything back together and everything lines up fine....for the most part.
The crossmember seems to have shrunk in length since I removed it as the bolt holes on the crossmember are now just a tad out of line with the holes in the undercariiage of the car. The misalignment of the holes is very slight, but enough to prevent all four bolts from going in.
After wrangling with this for some time, I decided that very slightly enlarging the holes on the crossmember would be the way to go, but I thought I would ask for a second opinion before doing so.
Thanks!
Wagons:
93 940
91 240
90 740
86 740
RickHaleParker
Has thanked: 3 times
Been thanked: 575 times
United States of America
RickHaleParker
Re: 91 240 wagon crossmember bolt holes
Post by RickHaleParker » Sun Aug 11, 2019 5:59 pm
The crossmember did not shrink, the holes moved further apart.
Lift the car at a point that will take some pressure off the stands which are pushing the holes further apart.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
e777
Year and Model:
Has thanked: 1 time
Been thanked: 0
e777
Post by e777 » Mon Aug 12, 2019 8:01 am
Excellent solution! I will remember that for next time. However, I ended up filing just a bit from the inside of the bolt holes on the crossmember, which allowed me to get the bolt through at the angle I needed. Given what you said, after lowering the car off the stands I'll definitely go back and snug up the bolts.
I was kidding about the shrinkage....lol
Thanks again!
Wagons:
93 940
91 240
90 740
86 740
