VIN's with Magneti Marelli ETM's? Topic is solved
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
I'm trying to determine whether my 2001 V70 T5 with manual transmission was originally shipped with the Magneti Marelli ETM. I'm the original owner, have lived at the same address since I bought the car new in 2001, and I never received any ETM recall notice from Volvo. I have received multiple recall notices from Volvo for the fuel pump issue. Having read thru the ETM forum multiple times, it appears that the suspect ETM seems to be based on model year, 2001 being in the recall. I would like to know if there is an original parts generator that will tell me what ETM I have based on my VIN. This would be easier for me then climbing under the car in 90+ degree heat to try to find the white Magneti Marelli tag on the ETM.
I've never had a throttle body issue, so I'm wondering if I'm lucky, whether my car was shipped with the upgraded ETM or whether having the manual transmission plays into the lack of a failure. By all rights, if I have the MM ETM, it should have given me problems long ago.
Any help/insight would be greatly appreciated. Thanks.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
How many miles are on your '01? I always ask this.
If I remember correctly, the occasions of engine stoppage whilst driving caught the attention of the feds (NTSB?) and Volvo extended the warranty to 10 years and 200K.
A coworker mentioned the severe hunting his car was exhibiting and that he had it replaced at his expense. I printed him the claim form I found online and because he fell within the extended warranty he got a full refund. He was grateful.
As I recall Volvo didn't host the site where I got the forms. I believe the government did but that was a while ago.
I sold my '02 (bought from the original owner-with dealer records-at 70K) at 198K. Neither of us had any ETM issue.
I remember seeing the MM logo molded into the plastic part of my ETM body but mine was a non-turbo.
Could a small mirror help with reading yours?
I've seen one picture of the mylar strip which had shed it's oxide. The wear was indeed concentrated.
Having a manual transmission might spread the wear out a bit. I do not know.
Could a dealership run your VIN and learn which ETM you got? I don't know.
People on these boards "always say" that the dealerships can only supply a customer with a new duplicate ETM (meaning the old, inferior design) so having XeMODeX rebuild yours when the time comes with improved materials is the way to go. Plus, there'd be no need to program anything as your is already married to your car.
93SCMax
Post by 93SCMax »
Thanks for your reply.
Car has just over 151k.
Saw the extended warranty was past due for my car (time wise), that's why I'm trying to determine whether I even have the MM ETM. I should have received a recall notice if I do have that ETM. Something doesn't add up.
Glad to hear your's ran without failure. I may be in the same lucky boat.
I could ask the local dealer, but felt asking here 1st was better...have not been impressed with the Hendricks Volvo dealership here in Charleston. They have done a few things over the years that make's it hard for me to patronize them.
I'll try an extension mirror or wait for cooler weather to crawl under her. I was just hoping to get a fast answer with the VIN since this topic has now caught my interest, and I want to get a plan in place if she starts acting up.
93SCMax
Post by 93SCMax »
Topic closed. I was able to get to an angle to where I could see the Magneti Marelli markings on the ETM. I guess my lack of a failure in 19 years is do to good living :D . I'll plan according for the inevitable.
Has thanked: 1609 times
Been thanked: 4063 times
We get a failure bias here on this and any other part failure
My first MM ETM failed at 137k
My parts car MM had 210K on it and is now living on another car.
I’ll guess the MTTF is between 150-200k
Your 2001,does have the MM ERM, 2002 was transition year to Bosch for non turbos, MM for turbos, then Bosch for P2s
The throttle bodies were not recalled, a new software was loaded which was more forgiving of mismatched throttle positon reports, and the warranty extended.
