Did you know? 🤔
02 XC70 Alarm Siren/UEM Woes
2001 - 2007 XC-70
BeachWagon
Year and Model: 2002 V70
Has thanked: 7 times
United States of America
BeachWagon
Post by BeachWagon » Mon Aug 12, 2019 12:24 pm
AS the title states, I have a 2002 V70 XC that I just picked up with a few problems. The sunroof and dome lights do not work. The information screen does not say anything about servicing the alarm system. My scanner can normally connect to the UEM in p2's such as my 02 V70.[we have a few wagons!]. The scanner was unable to connect to the XC70's UEM.
First repair attempt was disassembling the mirror, where several cold solder joints were taken care of. No change in the car's behavior. To be clear, the UEM is inside the mirror correct?
Second repair attempt was replacing the alarm siren module battery. The original battery was corroded to the point that the wire became disconnected. No damage to the PCB. Now that the alarm siren battery has been replaced, the alarm goes off for around 30 seconds, then shuts off for around 30 seconds. It continues this cycle over and over.
As a side note, the alarm siren will still go off even after i disconnect it from the car. If I unhook the siren battery, it stops. I can reconnect the siren battery and it will not go off until the siren is hooked back up to the car.
So here I am asking just what the hell is going on? I do not have Vida....working on that as one of my next purchases.
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 277 times
Canada
oragex
Re: 02 XC70 Alarm Siren/UEM Woes
Post by oragex » Mon Aug 12, 2019 1:39 pm
I think it would be normal for the module to keep sounding when it's disconnected. The correct battery is 7.2v 240mAh is if remember well - those chinese Ebay batteries have lower mAh and may not last many years
The alarm starts ringing when the something is not locked - maybe a trunk/hood/door micro switch is bad. Also check the 38 siren fuse (5amp I think). Another scenario to trigger the siren, is when the car battery is disconnected while the car is locked - maybe look at the power wires ?
The UEM is inside the rear view mirror indeed
Does the sunroof work when you unplug the siren module ? Should work. If not, try locking unlocking the driver's door 3 times with the key fob. See if it changed anything
BeachWagon
BeachWagon
Post by BeachWagon » Mon Aug 12, 2019 3:21 pm
I used a 7.2v 700mah Nimh battery. It's a replacement cordless phone battery. It does power the siren. Siren has since stopped. I suspect the battery was low on charge. Getting back to the UEM...my scanner is still unable to connect to it. CEM reports communication error with UEM as well. At this point, I believe the siren module is fine and I should be redirecting my attention to the UEM. Sunroof does not work when siren is unplugged. I've tried unlocking the door with the key three times as well as setting off the alarm and shutting it off by unlocking the door. No dice. I can't use the fob either so I know well there are still problems with the UEM. I'm a little suspicious of the voltage regulator on the UEM board. Gonna check that.
mark99tj
Year and Model: 2002 V70 XC
Has thanked: 0
Been thanked: 0
mark99tj
Post by mark99tj » Tue Aug 13, 2019 9:23 am
I had an issue last month where my battery was drained. I had parked my 2002 V70XC in my garage with the windows and sunroof open, and accidentally hit the panic button on the alarm (and my alarm does not sound due to the typical problems) and the lights flashed all night without me knowing and the battery drained. I had to jump the car in the morning, and once I did, the sunroof would not close. After trying a number of things, I pulled the fuse for the siren module. After putting it back in, essentially resetting it, the sunroof worked fine. From researching on other forums there does seem to be some sort of electrical interaction between the siren and the sunroof.
RickHaleParker
Has thanked: 3 times
Been thanked: 562 times
RickHaleParker
Post by RickHaleParker » Wed Aug 14, 2019 3:28 am
They are both on the same CAN Bus. If one or the other pulls down the CAN Bus. The UEM loses communication with both.
These users thanked the author RickHaleParker for the post:
firstv70volvo
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
BeachWagon
BeachWagon
Post by BeachWagon » Wed Aug 14, 2019 5:25 am
Yes, and if the UEM is dead[as it is in my case], it takes the keyless entry, sunroof and dome lights with it.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Thu Aug 15, 2019 9:47 am
Fuse 11C/6 .... ?
BeachWagon
BeachWagon
Post by BeachWagon » Tue Aug 20, 2019 7:51 pm
^one of the first things I checked. That fuse was pulled along with the alarm fuse. Of course I've since put all fuses in place and unfortunately the condition had not changed.
So here is the update. I went junkyard-spelunking today and grabbed FIVE P2 rear view mirrors. They charged me 5 bucks a piece for them. Two auto dim, three standard. Both autodims had leaking glass which is fine because my autodim glass is good. I've decided to jump fully down the rabbit hole of UEM repair so it's good to have a few spares. We will get to that in a minute.
I will first make a note that with no modification, one of the pillaged autodim mirrors worked when I plugged it in. Suddenly, my sunroof and dome lights came to life! I even got a little red light telling me to buckle up. Obviously, the keyless entry did NOT work. It is my understanding that the information contained in the main chip on my original mirror will have to be dumped to my replacement. NOW we're getting to the fun stuff!!!
This, keep in mind, is with the siren module DISCONNECTED. I lost daylight before I was able to see how everything behaves with the siren connected and operational. I will update findings once I try again with siren connected, and the new siren battery installed.
SO NOW WE GET TO THE FUN STUFF!!!
I have already disassembled the "new-to-me" UEM and compared the PCB to my original. After some cotton swabs and acetone, I was able to remove the conformal coating from all of the IC's on both units. After some searching and perusing through datasheets, I was able to determine the function of all of the aforementioned IC's. Both units have the same board part number, right down to the revision. Now we understand why the accessories work, but the keyless entry doesn't. The only difference the car sees is the security codes and serial number stored in the mirror. Where are those codes stored? In my case, that would be the Motorola 0K75F. AS a side note, I found out that these mirrors appear to contain one of three possible chips, one being the 0K75F. I'm sure that means three totally different boards. As luck may have it, both of my mirrors contain the same chips. All of the supporting components are the same. I also have pinouts to try applying power to my dead one for troubleshooting. It has a voltage regulator and a pair of power management IC's, so that's where I'll be looking. If I am unable to find a fault, I will be swapping the main chips between the two PCB's as a last resort effort.
Next update coming soon so stay tuned!
BeachWagon
BeachWagon
Post by BeachWagon » Mon Aug 26, 2019 11:58 am
Alright, so I have determined the failure to be somewhere in the chip specifically, either the chip itself has failed or the software has somehow corrupted.
After swapping the Motorola 0K75F chips between my original? UEM and the one I pulled from a junkyard, the problem has followed the chip. Now my original UEM with the chip swapped out for the donor works mostly. Dome lights and sunroof, but no keyless entry access. Makes sense because my chip which contains the coding for keyless entry, is now on the other board. Out of curiosity, I hooked up the one with my original chip and i get nothing. I guess a software reload to the UEM with my original chip is the next step.
Does a home Vida/Dice setup have the capability of reloading UEM software or do I have to head to a dealership?
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Aug 26, 2019 1:01 pm
Network sections are disabled in a "home" setup. Take it to a dealer.
