Did you know? 🤔
2000 v70 timing marks
2001 - 2007 XC-70
Mattvh
Year and Model: 2001 s 80
Has thanked: 1 time
Been thanked: 0
United States of America
Mattvh
Post by Mattvh » Tue Aug 13, 2019 5:13 am
I am trying to set timing marks on 2000 v70 Volvo. I am having a hard time with crank marks. Notice a few videos on 2001 and on or models around 1998. Are the 2000 to 2001 models the same. mine has two dots on the crank. Not sure if they should be at 1200 noon, or if there is a mark on engine block. Thank you
Has thanked: 272 times
Been thanked: 849 times
Trinidad & Tobago
Re: 2000 v70 timing marks
Post by abscate » Tue Aug 13, 2019 8:12 am
Your 2000 is the last of the Millennium P80 models, known affectionately here as 'the bastards'
Ill try to find the (non-TDC) timing mark picture and post. You are looking for two small lines that are different from the other sprocket teeth on the crankshaft - its hard to see but once you see it is is obvious
Link To Volvo Glossary
Mattvh
Has thanked: 1 time
Been thanked: 0
Mattvh
Post by Mattvh » Tue Aug 13, 2019 11:01 am
Thank you. With crank markings, it looks like there is a mark on the engine side and two marks on the crank. Would that be around 12:00 o’clock, or a little before or after? Thank you for the pic.
Georgeandkira
Year and Model: 2007 V70 base
Has thanked: 16 times
Been thanked: 45 times
Georgeandkira
Post by Georgeandkira » Tue Aug 13, 2019 1:55 pm
As usual, abscate's responses are right on.
The words I'd use to describe the crank marking is that it's a scratch down in the valley between two teeth of the sprocket. I was AMAZED at how "hidden in plain sight" it was. Align the top two marks then with a flashlight and a "long throw" magnifying glass (if necessary) look at the 12 o'clock position.
Honestly, I asked myself, "Are they -_-_ing kidding me?".
I repeatedly looked at the adjacent "valleys" to make certain they matched. The one in the middle (the timing mark) was the only one with such an incosistancy. A lot of words, I know, but I got it right and you will too.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 26 times
Been thanked: 51 times
MoVolvos
Post by MoVolvos » Tue Aug 13, 2019 6:53 pm
May or may not help. From a WP replacement in 12/2013.
viewtopic.php?t=60456
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Mattvh
Has thanked: 1 time
Been thanked: 0
Mattvh
Post by Mattvh » Wed Aug 14, 2019 10:02 am
Thank you again. I purchased the car for $500.00. Owner said the cam idealer broke in drive way at start. They replaced cam idealer and tried to start. The cam marks were of. I reset the marks, what I believe was wrong looking at picture, so we’ll reset when I get home from work. Not sure if I/they did damage by not having trimming marks set properly. Engine does turn over free.
Trinidad & Tobago
Post by abscate » Wed Aug 14, 2019 10:36 am
Ah. you have to stop there and do a compression test after you get the timing belt in the right place. If the engine was running hard when the belt breaks, the valves get bent and the cylinder head has to come off. A compression test will tell you where you are.
Mattvh
Has thanked: 1 time
Been thanked: 0
Mattvh
Post by Mattvh » Wed Aug 14, 2019 10:53 am
Ok I’ll have my work cut out after work. I’m getting better at this every day.
Mattvh
Has thanked: 1 time
Been thanked: 0
Mattvh
Post by Mattvh » Wed Aug 21, 2019 1:28 pm
Help, asking to see if this is the timing mark
