Did you know? πŸ€”
940 IAC - is it supposed to be wide open, or shut, with no power?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
SmittySmithsonite
Year and Model: 1993 940
Has thanked: 1 time
Been thanked: 0
United States of America
SmittySmithsonite
Post by SmittySmithsonite » Tue Aug 13, 2019 7:52 am
New member here. My expertise is on domestic vehicles. Trying to diagnose a bad IAC on this 940 with no service info - frustrating as hell!
Vehicle - '95 Volvo 940 wagon 2.3L 4-cylinder, Bosch system.
All my testing has narrowed it down to the IAC. What I want to know is, as the unit is sitting in my hand, should I be seeing right inside the unit through the port that's pointing down in the first pic? From what I've been reading, this should be closed off with no power applied. Also, this unit has 2 pins - not 3 - for the electrical connection. When I energize the unit, the shutter flips around briefly, and can barely be seen through the port. I can blow air through it regardless of having 12v at the pins, or 0v at the pins.
Thing looks fairly new, and is extremely clean inside as you can see. I sprayed some silicone spray in there to lube and clean things up a bit (not that it needed it - just in case it may have been sticking). Anyone ever looked inside one of these, or better yet, anyone have a known good one laying around to look at? I suspect I should be seeing the shutter closing off that port when there's no voltage applied to the pins. I just need 100% confirmation of this.
Any and all info will be greatly appreciated!
jimmy57
Has thanked: 4 times
Been thanked: 252 times
jimmy57
Re: 940 IAC - is it supposed to be wide open, or shut, with no power?
Post by jimmy57 » Tue Aug 13, 2019 1:47 pm
It should have a rest position for that valve that should give 900-1200 RPM idle.
These users thanked the author jimmy57 for the post:
SmittySmithsonite
SmittySmithsonite
Has thanked: 1 time
Been thanked: 0
SmittySmithsonite
Post by SmittySmithsonite » Fri Aug 23, 2019 2:00 pm
Thanks Jimmy - you're the only one who answered my question out of 3 forums. 8)
I finally have the answer here in my hand. Hopefully this will help someone else down the line who's attempting to keep these 940's on the road.
I hate winging parts at something without thorough troubleshooting, and being 200% sure that a new part will fix the problem. Without service info, I took a chance, based on my limited testing and observation of the old part, and purchased a brand new Bosch idle air control valve. Lo and behold, the shutter is 90% CLOSED on the new one! There's just a tiny opening to the left - 90% of the opening is blocked by the shutter. Exactly what I suspected. Made the right call, and for that I'm happy.
Here's pictures of the new unit taken in the exact location of the old unit in the post above (down the tube with the arrow on it).
New Bosch idle air control unit
Shutter 90% closed!
Slight opening (to left inside tube) to allow default idle air
93Regina
Year and Model: 93:240/940
Has thanked: 0
Been thanked: 64 times
93Regina
Post by 93Regina » Thu Aug 29, 2019 5:22 am
SmittySmithsonite wrote: ↑
Are you sure?
With a choke cable, hooked a water valve, one could rig up a manual IAC....homework is required, but it should work
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 35 times
Been thanked: 76 times
E Showell
Post by E Showell » Sat Nov 30, 2019 4:40 pm
What was the effect on drivability with the bad IAC?
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
93Regina
Has thanked: 0
93Regina
Post by 93Regina » Sat Nov 30, 2019 7:29 pm
E Showell wrote: ↑
IAC - Idle Air Control
IAC is related to idling RPM....irrelevant for roadway drivability...throttle plate is in control.
A bad IAC would have to be defined....stuck is what position...allows extra air, higher RPM...allows smaller amounts, lower RPM (stall out possible).
IIRC, IAC gets a "frequency" based signal (aka duty cycle) when throttle switch is in idle position. Once off idle switch position, your foot is in control
E Showell
E Showell
Post by E Showell » Sat Nov 30, 2019 7:35 pm
Reason I ask, daughter's H.S. buddy has a '92 940. I am told it can't be driven over about 40 mph. Not exactly sure what the issue is. I'll try to get more data and report back.
'95 855 auto (sold)
93Regina
Has thanked: 0
93Regina
Post by 93Regina » Sun Dec 01, 2019 8:01 am
E Showell wrote: ↑
LH 2.4 has a limp home mode....Rex-I/Regina I've never heard of a limp home mode.
Bypassing FPR, or low rail pressure (fuel pump or filter defective) would be suspect....by 1993, there was a quick test for checking rail pressure at rail.
E Showell
E Showell
Post by E Showell » Sun Dec 01, 2019 8:17 am
Overdrive relay bad?
'95 855 auto (sold)
93Regina
Has thanked: 0
93Regina
Post by 93Regina » Sun Dec 01, 2019 10:22 am
E Showell wrote: ↑
940s could have had AW70s, or AW71Ls transmissions.
Kickdown cable may not be working correctly....so upper range gears are absent. If so, engine most likely is using higher RPMs
OD relay circuit would only affect shifting into OD...higher speeds than 40mph exist....when OD is kicked out, this is for heavy loads or mountain like driving. Hence, 65 mph....
Kickdown cables fail...they all get replaced....hence, if a gear shifting issue, kickdown cable needs replacement, or valve-body has an issue.
