Did you know? 🤔
Rear shocks and Impact driver questions.
2001 - 2007 XC-70
AlanS
Year and Model:
Has thanked: 0
Been thanked: 0
AlanS
Post by AlanS » Tue Aug 13, 2019 5:42 pm
Having just come from the mechanic, I am told I need rear shocks...front tie rods (inner and outer). I looked up any YouTube videos, found ones for S60, S80, XC90, etc. But none specific to my 2006 XC70. What models are IDENTICAL to my car? This way I can see if I want to tackle this myself.
Lastly, I only have hand tools. Would an electric impact driver work well enough to get one? I would like to go 'cheap' (ala Harbor Freight)...do the job and just have the tool around ....Not interested in doing much more with it....I'm old now...I get tired quickly.
SuperHerman
Has thanked: 0
Been thanked: 128 times
United States of America
SuperHerman
Re: Rear shocks and Impact driver questions.
Post by SuperHerman » Tue Aug 13, 2019 7:11 pm
First you need to find out what type of shocks your vehicle has - specifically whether they are normal or self leveling. From that point pick your video for a V70 or XC70 (2001-2006) for the shock type you have. To be honest the manner to change them is the same - the only difference is getting to the inside nuts. You have to take off some parts and move some carpet. Fairly easy. So picking a V70 or XC70 of the mentioned years will show you what to do.
This is video explains the process - at the end you will see install with out air - so do the reverse for removal.
Here for the wagon:
Look up the part at one of the site sponsors, but before you do pull the part number from the shock on the car.
Rattnalle
Has thanked: 17 times
Been thanked: 121 times
Sweden
Rattnalle
Post by Rattnalle » Tue Aug 13, 2019 11:10 pm
Hold on. The XC70 Will have AWD. That makes it different from all the non-AWD cars which are really simple as shown above. It should be the same as on the S60 or V70 AWD models though.
Has thanked: 248 times
Been thanked: 807 times
Trinidad & Tobago
Post by abscate » Wed Aug 14, 2019 4:29 am
Alan...see the thread from Enotslim on spring And shock change. With a helper, the hard part of getting the control arm down far enough to get the strut back on is easy. By yourself, not easy.
Other than that step, it is bolt off/on, no impact needed.
You can buy ready made struts or take the struts And springs to an independent to put together , off car.
Reason: Hypertexted a the link
Link To Volvo Glossary
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 47 times
vtl
Post by vtl » Wed Aug 14, 2019 7:54 am
With the proper tools this is a one slacking man job :)
First, unbolt the front stay at the wheel hub housing. Loose the front stay's bolt at the subframe, the stay should drop down. This allows control arm to travel further down with much less force. I am usually able press the arm down with my leg and mount the shock onto the arm, otherwise a bottle- or scissor-jack can press the arm down for you, just position it on the arm and press against the body.
To get the stay back onto the housing you need to jack the arm at the proper height so the holes would align. The trick is to position the jack along the car, so it will be pulling the housing towards the front of the car:
This is a FWD car, but you get the idea.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
xHeart
Year and Model: 1997 854 NA
Has thanked: 18 times
Been thanked: 32 times
xHeart
Post by xHeart » Wed Aug 14, 2019 9:03 am
You can use impact driver, 1/2" is heavy to hold, but why?
I took apart the rear to service the final drive. Most fasteners (bolts and nuts) were from aluminum material. 1/2 & 3/8 breaker bars will get you started. Craftsman hand tools are my favorite.
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
Has thanked: 75 times
Been thanked: 237 times
Post by erikv11 » Wed Aug 14, 2019 10:47 am
Not sure there will be a ton of use for the impact on this job, but it is nice to have around over the long term.
I have a cheap Harbor Freight 1/2" impact, the corded one. Like xHeart says it is heavy and sometimes bulky (so that you must have extensions and an impact swivel), but otherwise it is a great tool. Has lasted a very long time and still performs very well. Great for spinning lug nuts off. I have removed probably 16 front axle nuts with this wrench, with the car in the air and many of them midwest-20-year-old-rusty-grade, and the impact tool has never let me down. I now have a compact air impact so don't use the HF unit very much but it comes out every time I pull a front axle, which has been too often recently.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 160k
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 493 times
Been thanked: 178 times
matthew1
Post by matthew1 » Wed Aug 14, 2019 12:55 pm
Alan, here's the topic thread Abscate mentioned above (now linked in his post): 2004 XC70 Broken Rear Spring Fix
Like the others have said, the half-inch AC impact class of tools will never let you down on tough nuts. I have one. I used it often on my 850's front suspension jobs and lug nuts. But it's heavy.
I wouldn't buy one for one job, but for many jobs down the road, yes.
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
