Did you know? 🤔
Ford power steering fluid?
2001 - 2007 XC-70
qwertyjjj
Year and Model: V70 2004
Has thanked: 0
Been thanked: 0
qwertyjjj
Post by qwertyjjj » Tue Aug 13, 2019 8:25 pm
Can I use ford/gm power steering fluid in a v70 2004?
The bottle has no other markings but days entry it works for 'European Cars'.
The only other bottle I can find for Volvo is fairly expensive.
What's the difference? I thought the fluid was all the same
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 26 times
Been thanked: 49 times
United States of America
MoVolvos
Re: Ford power steering fluid?
Post by MoVolvos » Tue Aug 13, 2019 9:08 pm
Should use DEX III which mean everything but Ford Type F products.
https://www.amazon.com/Castrol-06820-TR ... 3JV9VX4XF7
https://www.amazon.com/Valvoline-VV324- ... 3JV9VX4XF7
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Katten
Year and Model: S80 2002
Has thanked: 0
Sweden
Katten
Post by Katten » Tue Aug 13, 2019 10:52 pm
Volvo P2 cars dont use Dexron III as far as I know. Dexron is red, all P2 cars Ive seen has green PS fluid.
CHF 202 is the correct stuff if memory serves correct.
Specification needs to meet FORD WSS-M2C204-A2
But as always if you get original Volvo you wont have to worry :). I run FORD WSS-M2C204-A in my car and it seems to work, tho if I where to replace it Id get the CHF 202 with FORD WSS-M2C204-A2 specification.
Has thanked: 74 times
Been thanked: 237 times
Post by erikv11 » Tue Aug 13, 2019 10:56 pm
I definitely wouldn't just add ATF.
Your 2004 V70 came from the factory with Pentosin CHF-11S for power steering fluid. This is a green colored fluid, turns green brown when it gets old.
That said, DexIII ATF will also work just fine in your 04 V70 and it is possible someone has switched it to Dex III somewhere along the way. Dex is a red fluid, turns to red brown when it gets old.
You can use either one but it is best that you don't mix them, so I would first figure out what you have in there now.
Pull the dipstick from the PS reservoir, dab a little bit on a white paper towel and check the color. The you can add the matching fluid. If you're unsure which one it is then post up a pic and we'll help you figure it out.
If you need green CHF-11S type fluid, a cheap and reliable way to go is "Prestone European power steering fluid" about 7 bucks for a small bottle. Or you can buy a larger can of Pentosin CHF-11S at the auto parts store etc, more like 20 bucks. If you need red ATF then those ones suggested by MoVolvos are fine.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 160k
Katten
Has thanked: 0
Sweden
Katten
Post by Katten » Tue Aug 13, 2019 11:03 pm
To tie erikv11s post to mine, the CHF-11S is FORD WSS-M2C204-A specified which I run currently :).
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 47 times
vtl
Post by vtl » Wed Aug 14, 2019 7:57 am
FYI, ATF was foaming in my 02 V70, pump was grinding heavily.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
jimmy57
Has thanked: 2 times
Been thanked: 204 times
jimmy57
Post by jimmy57 » Wed Aug 14, 2019 8:43 am
Volvo changed to Pentosin in late 90's due to steering shudder and pipe rattling noise from power steering lines. ATF and regular power steering fluid can get dissolved gas (aerated, entrained air, choose your terms) and the hydraulic hammer that this leads to causes shock waves as pressure limiter valve on pump pops open at full lock and when steering effort is high. The air in fluid also makes pump noisy. The Pentosin CHF 11S was the first used, 98-2002 and they switched to CHF 202 since then. This is almosy universal with European brands. It is not supposed to be mixed with ATF as that increases the foaming tendency but it is not harmful to seals or pump, etc. There is also an orifice fitted to return line since late 90's to help with the growling pump and the thumping in lines.
Post by erikv11 » Wed Aug 14, 2019 9:45 am
... It is not supposed to be mixed with ATF as that increases the foaming tendency but it is not harmful to seals or pump, etc. ...
I have long wondered why they are not supposed to be mixed, super useful to know thank you.
It is no problem at all mixing CHF-11S and CHF-202 so OP you could also just go to the CHF-202 if your car currently has green.
'96 855 NA, 145k
'06 S60 R, 160k
MoVolvos
MoVolvos
Post by MoVolvos » Wed Aug 14, 2019 5:40 pm
Trust Me the Red ATF III or anything exceeding or compatible will work. JS3309 Multi-Vehicle Trans-Fluid will work.
Experience: 20+ yrs volvo technician, Ase A1-A8, L1, A/C certified
Volvo Mechanic: Mike, volvo Tech
"you should use the volvo power steering fluid, but if I recall correctly in your owners manual it still state you can use ATF dexron III. I will double check and get back to you in a couple of minutes. thanks Mike
Yes you can still use ATF dexron III in the power steering system."
https://www.justanswer.com/volvo/1kasy- ... d-use.html
From the Volvo 2004 V70 Owner's Manual - Does not state Dextron III but generic ATF so it's used in the shops. Trans-fluid has improved so much over the years the additive package exceeds most OEM fluids
Power steering fluid
ATF fluid
Volume: 0.95 US qts (0.9 liters)
https://volvo.custhelp.com/app/manuals/ ... /om_id/616
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Post by erikv11 » Wed Aug 14, 2019 7:10 pm
Yeah well, I definitely wouldn't just add ATF, as stated.
And the owner's manual is well known to be wrong about ATF in the power steering reservoir for the 01-04 P2 cars, do some searching.
'96 855 NA, 145k
'06 S60 R, 160k
