Did you know? 🤔
96 850 no spark
joaa
Year and Model: 96 850
Has thanked: 0
Been thanked: 0
United States of America
joaa
96 850 no spark
Post by joaa » Wed Aug 14, 2019 11:46 am
I'm working on a 96 850 with no spark. The owner has already changed the cam and crank sensor both new and a new coil. Also the ECM was changed but with a used one. Still no spark .
The owner also said last year he had to turn the key back off then back on before it would do anything but it hasnt done it for a year or more. Ignition switch maybe?
I tested at the coil with my logic tester and power but no pulse. Any ideas? All ideas appreciated and thankful for.
jreed
Has thanked: 44 times
Been thanked: 26 times
jreed
Re: 96 850 no spark
Post by jreed » Thu Aug 15, 2019 5:15 am
Interesting problem... just confirming that the car cranks but does not start?
greg850r
Year and Model: a long list
Has thanked: 4 times
Been thanked: 9 times
greg850r
Re: 96 850 no spark
Post by greg850r » Thu Aug 15, 2019 6:11 am
I would recheck the connections and routing of cam sensor and crank sensor. The plugs get brittle and fall apart over time. Next I'd throw a cap and rotor at it. I chased one of these for a very long time. Bad ground could do it. Mine turned out to be loose positive cable at the starter causing intermittent interruptions to 12v at ECU.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
dj_v70
Year and Model: v70 2003
Has thanked: 5 times
Been thanked: 17 times
dj_v70
Re: 96 850 no spark
Post by dj_v70 » Thu Aug 15, 2019 7:24 am
a) Did you use your logic probe to test crankshaft/cam sensors at ECU connector?
b) If you have 12V on high side of coil then ignition switch is at least partially working. Did you test for power at ECU?
c) Did you test wire from ECU to coil?
Has thanked: 75 times
Been thanked: 237 times
Re: 96 850 no spark
Post by erikv11 » Thu Aug 15, 2019 9:13 am
... The owner also said last year he had to turn the key back off then back on before it would do anything but it hasnt done it for a year or more. Ignition switch maybe?
Given that the electrical part of this switch is extremely common to fail, if troubleshooting is going nowhere I'd swap in a known working one. E.g. any ignition switch at the junkyard will be a working one.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 160k
RickHaleParker
Has thanked: 3 times
Been thanked: 412 times
RickHaleParker
Re: 96 850 no spark
Post by RickHaleParker » Thu Aug 15, 2019 10:00 am
Before or after the DI Power Stage?
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
joaa
Has thanked: 0
Been thanked: 0
joaa
Re: 96 850 no spark
Post by joaa » Thu Aug 15, 2019 1:14 pm
Sorry guys I got busy. I run my own shop but very few imports get this deep in the woods. Anyway back to my Volvo problem, So far all Ive tested were the contacts on the coil itself. Correct me if I'm wrong-- shouldn't the negative side of the coil pulse as the engine cranks?
I've cleaned and replaced all the grounds I could find body and motor still no fire. Ideas? BTW thanks for the quick replies!
RickHaleParker
RickHaleParker
Re: 96 850 no spark
Post by RickHaleParker » Thu Aug 15, 2019 3:06 pm
On the Coil's primary side or DI power stage output (Solid Red & Solid Blue) it should pulse.
If there is no pulse from the ECM (Yellow/White), No DI Power stage 12V supply (Blue/Red) , No DI Power stage ground (Solid Black) or DI power stage is defective you won't.
The DI power stage is mounted on the same bracket as the coil.
joaa
Has thanked: 0
Been thanked: 0
joaa
Re: 96 850 no spark
Post by joaa » Fri Aug 16, 2019 5:50 am
The DI is new along with the new coil which I've found makes no difference. I've gotten bad new parts before. I'll do some more checking this evening after work and let you know what I find. Again thank you
