PCV breather box replacment pdf/slide show
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
Prepping for my first real work on my 2004 XC70
Sharing and open for comments/notes and extra info.
based on FCP EURO youtube video.
Also- a possible PCV modification on one hose for high mileage engines.
(done on a 1998 Volvo S70 GL, but similar hose replacement)
viewtopic.php?f=1&t=53448
STEP BY STEP SLIDESHOW/PDF
And general torque list:
Sharing the long OEM torque list :wink:
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Oh my God of Coincidences! I'm looking at a 2004 XC-90 with the same engine tomorrow.
Thanks
Mikele82
Post by Mikele82 »
Good luck, let me know if you have fresh notes to add after your xc90 project :)
For me visual steps slideshow works best and easier than scrolling paper notes or video while working.
I wanna do a Timing belt + water pump slide show pdf and share soon as well.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Just my 0.00002c but I really don't like those worm clamps on the PCV. When I did my PCV, I put a worm clamp - and it was actually the Volvo kind which is less prone to loosen by itself, and when I drove the car the worm clamp got slack and the PCV hose popped off. Lots of fun trying to push that hose back in place from under the intake manifold.
Really only use Oeticker clamps (the tool sells for $10 from China), and clean thoroughly the metal surface of any oils before sliding over and clamping any hose.
clamp tool.jpg (20.79 KiB) Viewed 4522 times
Georgeandkira
To Mikele82 and everyone else. I saw, drove and pulled codes from the XC-90 today.
There were 17 codes several of which were seemingly connected. There were a few I didn't have a clue about.
I starting a new thread for it for clarity.
Please read it and help my sorry....you know. G&K
jamadams11
Year and Model: 2004 XC90
Post by jamadams11 »
On an engine with a badly plugged system, the drain at the bottom can be clogged in the oil pan/sump.
to clean the pan, it must be removed, thoroughly cleaned and re-installed.
