95 Volvo 960 Injectors Don't Pulse Without Starter Fluid
brads960
Year and Model: 1995 960
Post by brads960 »
My car will not start without using starter fluid. It seems it is because the fuel injectors are not pulsing; they are getting power, but it remains constant until the car is started with fluid, and then they begin to pulse as they should.
Any help is much appreciated!
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Leave the key in POS II for 15 seconds before cranking engine, see if that makes a difference.
Active
Past
Frank1894
Year and Model: 1993 Volvo 960
Has thanked: 1 time
Post by Frank1894 »
I have a 1993 960 wagon. Same problem need start fluid then runs great, got fuel at the rail, replaced the crank sensor, Mass Air Filter is good, relays good, once started it will restart after being driven, but will not start the next day or a few days later.
