Did you know? 🤔
2008 V70 P0190 FUEL PRESSURE SENSOR!!
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
Liason
Year and Model: 2012
Has thanked: 0
Been thanked: 0
Algeria
Liason
Post by Liason » Sat Aug 17, 2019 3:24 am
Was getting P0190 & car was occasionally cutting out. Replacing the fuel pressure sensor was an easy fix.
Original part # Volvo 30756097 Bosch 0261230110. Google search brought up a number of 'reasonable' priced alternatives. See internet cafe games
.. -and-parts and http://forums.swedespeed.com/showthread ... -T5-engine
I purchase Napa 2-260017 for $89.00
Steps:
1) Removed fuel pump fuse ( #22 under glove compartment)
2) Turned over engine a few times to reduce pressure in system
3) Detached battery & covered terminal
4) Remove engine cover
5) FPS is on right side of fuel rail. Place rags under sensor to catch excess gas
6) Usef torx 25 key to remove bolt holding sensor. Hard to see & tight fit. This was the hardest part - getting the key into the small space and snug into the bolt.
7) remove sensor and detach wiring clip
8) reverse steps to install.
9) Enable ignition w/o starting & confirm no pressure leaks
10) Start car & confirm no pressure leaks.
Took about 45 minutes & saved about $400 over dealer quote.
Also found it interesting that there was a recall in 2004 for the same FPS (same part #). When I asked the dealer about it they replied that it was probably a 'bad batch' of sensors and the recall only applied to 2004 model years (or something - it is Recall 181). I find it strange that there would be a recall for a particular part from 2004 but they would continue to use the same Bosch \ Volvo part number.
