Hy buddies,
I open again the subject I've closed myself few week ago because I can't manage to rebuild my wire correctly. I mean the air wire around the fuel wire.
The engine turns correctly but I have a hose that is not plugged to anything. So I need your help.As you can see on the photo, this with -yellow small hose isn't connected. When I put my finger in it, it is aspired, the turn round looses a bit energy then re starts as normal.
May someone who may have the same engine than me (B5could post here some pictures of the differents hoses , where they are connected, where they go.. I'm the fog on this issu.
Rear springs
The nut that hold the bottom of the springs turn around when I I try to unscrew then. Is there a another way than using a torch or angle wheel to get them off ?
Door key cylinder
The driver side (LHD) doesn't accept the hole key. Is it possible to switch it with the front passenger door cylinder, or switch it with the one in the trunk ? I was thinking about switch the all door cylinders + Ignition and remote receiver from my old V70 from 1998. The question is to know if the only way to get the ignition one from the V70 is to use a drill and a metal drill bit ?
Thanks to ones that will bring me theirs knowledges, pictures and or board.
Manov
850 engine air hoses - rear springs - door cylinder & ignition
crlande
- Year and Model: 240DL;850;S70
- Has thanked: 1 time
- Been thanked: 36 times
The bolt on your spring anchor has splines on the head where it rests in the anchor. If the nut and bolt are spinning, they are stripped. I drilled at an angle into the bolt head and then lodged a something into the hole to keep the bolt from spinning. Spring anchor which comes with a new bolt. $13 U.S.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 673 times
- Been thanked: 163 times
Thank you for your answer. But I don't have a bolt and nut system, I have a threaded rod and the top is just flat. I will try to block it by under the bolt, with a water clamp. I'm not really warm to use an angle wheel because the fuel tank is around...
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
Use a fan. A good breeze will keep any fumes away and you can grind safely as long as you keep the sparks in the right direction.manovlov wrote: 17 Aug 2019, 23:10 Thank you for your answer. But I don't have a bolt and nut system, I have a threaded rod and the top is just flat. I will try to block it by under the bolt, with a water clamp. I'm not really warm to use an angle wheel because the fuel tank is around...
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- Has thanked: 311 times
- Been thanked: 817 times
Vacuum lines: viewtopic.php?f=1&t=65002
- manovlov
Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks ! Thanks !
Manov
- manovlov
Yes, it is exactly why I have considerably increased my swearword stock !crlande wrote: 18 Aug 2019, 04:32 Are you sure do not have this holding the spring down? https://www.fcpeuro.com/products/volvo- ... 35#fitment
He won't be so smart when I blow his head off.
I have no other way than warm it till 3000 ° ...
crlande
Drill baby drill! right thru the flat part of the bolt head....because when you get that nut off with heat you will not be able to install the nut on the bolt as I still believe the splines (very similar to the windshield wiper arms) are stripped and it will keep spinning in the socket.
- 18 Replies
- 15099 Views
Last post by LadieRed
- 1371 Views
Last post by Georgeandkira
- 2859 Views
- 2161 Views
Last post by precopster
- 5610 Views
Last post by EanBarnard
