Did you know? 🤔
Rear brakes from XC90 - Possible?
2001 - 2007 XC-70
Zolll
Year and Model: 1998 V70 AWD
Has thanked: 2 times
Been thanked: 0
Zolll
Post by Zolll » Sun Aug 18, 2019 6:38 pm
Hi! I was wondering whether it’s possible to install the rear brakes of an XC90 onto my 2004 XC70 (caliper, bracket, rotor, pads, line). Couldn’t find anything in the search function.
I have done the 305mm upgrade for the front but I’m still disappointed with the braking performance in general and especially when towing my trailer.
Thanks for your help!!
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 42 times
United States of America
vtl
Re: Rear brakes from XC90 - Possible?
Post by vtl » Mon Aug 19, 2019 2:17 pm
80% of brake performance comes from the front. Very little need in a bigger rear brakes.
The reason why P2 brake feel weak is hidden in its brake booster. Some people replace it with one from P1 platform, like from V50 (some custom adapter is required), some modify the booster: it has a spring that controls the amount of brake pedal's travel before the booster kicks in. Booster and the brakes themselves are more beefy and capable than in most of Toyota's, for example, where the brakes are much more catchy.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
Zolll
Been thanked: 0
Zolll
Post by Zolll » Tue Aug 20, 2019 1:20 pm
Thanks! I may look at improved brake lines to improve brake pedal feel..
vtl
vtl
Post by vtl » Tue Aug 20, 2019 2:21 pm
Doesn't matter, you need to tweak booster.
IslandV70
Year and Model: 2005 V70 2.4
IslandV70
Post by IslandV70 » Wed Aug 21, 2019 6:51 am
Any links to how to do this? THANKS
These users thanked the author IslandV70 for the post:
Zolll
ndphotonl
Year and Model: S80 2.4T Wasa
Has thanked: 17 times
Been thanked: 22 times
Netherlands
ndphotonl
Post by ndphotonl » Wed Aug 21, 2019 2:37 pm
Would also like to read about this
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
vtl
vtl
Post by vtl » Wed Aug 21, 2019 3:40 pm
These users thanked the author vtl for the post:
ndphotonl
Year and Model: Lots
Has thanked: 4 times
Been thanked: 103 times
Australia
Post by precopster » Thu Aug 22, 2019 5:10 am
Does your 2004 have a working vacuum boost motor? When they fail you can lose a lot of braking power......
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
Zolll
Been thanked: 0
Zolll
Post by Zolll » Tue Aug 27, 2019 8:27 am
Yes it does!
Zolll
Been thanked: 0
Zolll
Post by Zolll » Tue Sep 10, 2019 1:04 pm
To anyone wondering if the XC90 rear brakes swap is worth it, do it!! The brake performance and brake feel is night and day with the XC90's 308mm rear brakes and larger calipers. Before, it felt as if all the weight was transferred to the front and the steering would feel very heavy. Also, the brakes suffered from fade despite having very decent parts installed - now, it just stops without any drama.
I was lucky to find a wrecked 2005 XC90 that had new pads, rotors, as well as calipers in 9/10 shape (the factory cross hatch pattern still visible on the rotors). Everything bolts up directly with the caliper carrier. I had to cut the XC70's brake shield for clearance but will order new XC90 ones.
