Did you know? 🤔
DIY motor mount rubber injection fail
2001 - 2007 XC-70
IslandV70
Year and Model: 2005 V70 2.4
Has thanked: 2 times
United States of America
IslandV70
Post by IslandV70 » Tue Aug 20, 2019 12:38 pm
The stock top motor mount was too loose for my taste, so I bought one of the urethane mounts and installed that. The car drove great but vibrated too much :(
I bought a new stock mount and I was back to square 1, too loose but no vibration. I got the idea to fill the air spaces in the mount with silicone rubber. I bought some 2-part mix from Amazon and filled the mount with it. Now the car drives great but the vibration is about 90% as much as the urethane mount and the stock mount plus the rubber mix cost more than the urethane mount :(
I am sticking with it for now because I just hate sloppy mounts.
jimmy57
Been thanked: 196 times
jimmy57
Re: DIY motor mount rubber injection fail
Post by jimmy57 » Tue Aug 20, 2019 12:43 pm
What issues did the standard mount cause? I question what the long term effects will be from a harder mount.
Katten
Year and Model: S80 2002
Has thanked: 0
Sweden
Katten
Post by Katten » Tue Aug 20, 2019 1:07 pm
I filled my stock mount with glass sealer which was very soft, 15 shore I think. Still vibrated like crazy! Drilled lots of holes in it and tightend the mojnt with car in D if memory serves. Now it is ok but mojnt is not any stiffer then a new stock mount :D.
I believe the mount must be very loose/flexible to not get vibrarions in the cabin. I'd stick with stock, only filled mine because the rubber had split some on mine and was too cheap to buy a new one haha.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 23 times
Been thanked: 44 times
MoVolvos
Post by MoVolvos » Tue Aug 20, 2019 7:27 pm
I did the same thing except with roofing material. If the mount was new one could try just adding the rubber tubing without the sealer. I do notice a little more noise but not at idle. It was most likely from the strut tower mounts being solid now.
viewtopic.php?f=1&t=89740&p=509540#p509540
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
ndphotonl
Year and Model: S80 2.4T Wasa
Has thanked: 17 times
Been thanked: 22 times
Netherlands
ndphotonl
Post by ndphotonl » Sun Aug 25, 2019 9:56 am
I have the round SuperPro insert and I can tell you it loses some of the harshness over time. Also, I pay less attention to it :)
ImageVolvo S80 2.4T Removing the Upper Engine Mount OEM bushing by Andy Ramdin, on Flickr
ImageVolvo S80 2.4T Polyurethane Upper Engine Mount vs OEM top view by Andy Ramdin, on Flickr
ImageVolvo S80 2.4T Polyurethane Upper Engine Mount completed by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
IslandV70
IslandV70
Post by IslandV70 » Sun Aug 25, 2019 12:52 pm
The rubber is getting quieter now. I like how it drives enough to put up with it.
- Pete -
Has thanked: 27 times
Been thanked: 39 times
- Pete -
Post by - Pete - » Sun Aug 25, 2019 2:10 pm
$23.15 for a new one that is every bit as good as the updated original.
I’ve been running one for ~20k miles. I’ve run the poly ones before, not to my liking and they eventually crumble into pieces.
https://rover.ebay.com/rover/0/0/0?mpre ... 2546755402
2001 V70XC 142k
2004 V70 AWD 134k
2004 V70R M66 142k
2004 XC70 278k
2006 XC70 155k Sold
