Folks,
Okay, so here's the deal- when I am driving, and let off on the gas, or (sometimes) accelerate, the V70 makes a popping or "clunk" sound. The sound comes from the front right side of the car (as seen from inside the car). We can replicate the sound while sitting by shifting back and forth into drive and reverse and revving the engine with the brakes applied. In the last thousand miles or so, I've replaced the upper engine mount, the lower torque mount (transmission to subframe), and the "front" engine mount (which attaches the engine to the subframe under the crankshaft pulley). In fact, replacing the last one seemed to fix the problem for a little while. I've checked the other two engine mounts (the cylindrical hydraulic mounts) and while both are clearly old, they don't look too bad. There's no leakage I can see, no torn rubber, etc. They are collapsed somewhat as I can move the wire straps a bit. Maybe a half inch? Oh, and the car has 216,000 miles and there's no indication that these mounts have been replaced. I have repair records,but no idea if the records I have are a complete list or not. Lastly, I had it up on ramps, and I can see that lower mount flex, but it is not collapsed or moving a lot. The original lower mount did the same thing, though it was more loose- I could flex it by hand. Years of leaking oil had softened the rubber, but it too wasn't collapsed in the typical way you see them fail.
So, the questions are these-
- How do I tell if those cylindrical mounts are bad, short of the obvious indications of collapse?
-What else might be wrong with it?
- How problematic is it to drive the car? The sound is unpleasant but it doesn't appear to do any damage.
Thanks in advance, everyone!
Bert
Question about P2 Engine/Transaxle Mount Failure
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
So, MDK here. Those other 2 I call acorn's. That's what they look like.. big acorn's. 2 me it sounds like sway bar bushings or maybe lower control arm bushings. Have you ever replaced the upper spring seats? Those make a poping noise. Usually the acorn's leak fluid..
- June
- Has thanked: 523 times
- Been thanked: 261 times
My 2004 P2 it was the subframe bushings. Absolutely drove me crazy enough to replace every suspension part to no avail. Then the rear main seal sprung a leak and I insisted the subframe bushings were to be replaced since the frame was on the ground. To my surprise it cured the problem. So if everything else checks out consider the bushings. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- KidsV70
- Year and Model: 2002 V70
- Has thanked: 12 times
- Been thanked: 4 times
The upper spring seats look ok from the top , FWIW. Wouldn't the car have to be moving for those to make noise?MDK wrote: 21 Aug 2019, 20:23 So, MDK here. Those other 2 I call acorn's. That's what they look like.. big acorn's. 2 me it sounds like sway bar bushings or maybe lower control arm bushings. Have you ever replaced the upper spring seats? Those make a poping noise. Usually the acorn's leak fluid..
Thanks!
- KidsV70
Interesting, June. Can you explain more about what you mean by subframe bushings, though?June wrote: 21 Aug 2019, 20:31 My 2004 P2 it was the subframe bushings. Absolutely drove me crazy enough to replace every suspension part to no avail. Then the rear main seal sprung a leak and I insisted the subframe bushings were to be replaced since the frame was on the ground. To my surprise it cured the problem. So if everything else checks out consider the bushings. June
- KidsV70
Oops! It's front wheel drive, so no collar sleeve. I should definitely check the front CV though. Thanks!vtl wrote: 21 Aug 2019, 20:36 Almost stripped collar sleeve can do that. Propeller shaft's front CV joint, too.
- June
Here are photos of the subframe and a genuine Volvo new subframe bushing. The subframe is where the lower engine mounts attach the engine/ transmission and suspension to the body of the car. The rubber bushings wear out and make a popping sound with the engine torque. Also when they get really bad the car will pull one way than the other going down the road. JuneKidsV70 wrote: 22 Aug 2019, 17:30Interesting, June. Can you explain more about what you mean by subframe bushings, though?June wrote: 21 Aug 2019, 20:31 My 2004 P2 it was the subframe bushings. Absolutely drove me crazy enough to replace every suspension part to no avail. Then the rear main seal sprung a leak and I insisted the subframe bushings were to be replaced since the frame was on the ground. To my surprise it cured the problem. So if everything else checks out consider the bushings. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- June
Also the bolts are torque to yield one time use only. So new bolts must be installed. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- 889 Views
Last post by theWIFES_S70
- 1377 Views
Last post by Ozark Lee
- 1660 Views
Last post by MadeInJapan
- 79 Replies
- 17781 Views
Last post by 01_Nautic_V70
- 742 Views
Last post by Nadiamarie22
