My 2000 v70 normally aspirated base model has started creaking from the rear end, so today I got under the car and found the culprit-- the driver's side rear spring is rubbing on the trailing arm during suspension travel. Has anyone else encountered this before?
The car did have an alignment this spring after front suspension work, but this problem is new. I took a quick look at the spring and its mounts, I couldn't see anything obviously wrong.
Let me know what you think-- thanks!
2000 V70 rear spring rubbing on trailing arm
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
Only partly familiar with the rear suspension and only with FWD (not AWD) cars, but there is a sort of ball joint where the delta link connects the horizontal arm to the body of the car. Might want to take a close look at that. I am guessing that if you take the weight off of the wheel (possibly both rear wheels) and move things around, you would be able to see or feel any play in the delta link or any bushings. With the weight on the wheels, it might be hard to tell unless it is visually obvious.
All U.S. market models.
All running and on the road.
- Has thanked: 2196 times
- Been thanked: 1850 times
Also check for broken mountings on the rear axles. I have had them rot through and the aluminum crack.
- 1027 Views
Last post by LOB
- 2432 Views
Last post by Kazthebassman
- 2900 Views
- 574 Views
Last post by vtl
- 2722 Views
Last post by h20ham
