Did you know? 🤔
2000 V70 rear spring rubbing on trailing arm
Herb Goltz
Year and Model: V70 2000
Has thanked: 1 time
Canada
Herb Goltz
Post by Herb Goltz » Wed Aug 21, 2019 9:55 pm
My 2000 v70 normally aspirated base model has started creaking from the rear end, so today I got under the car and found the culprit-- the driver's side rear spring is rubbing on the trailing arm during suspension travel. Has anyone else encountered this before?
The car did have an alignment this spring after front suspension work, but this problem is new. I took a quick look at the spring and its mounts, I couldn't see anything obviously wrong.
Let me know what you think-- thanks!
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 12 times
Been thanked: 17 times
United States of America
Eddystone
Re: 2000 V70 rear spring rubbing on trailing arm
Post by Eddystone » Thu Aug 22, 2019 11:03 am
Only partly familiar with the rear suspension and only with FWD (not AWD) cars, but there is a sort of ball joint where the delta link connects the horizontal arm to the body of the car. Might want to take a close look at that. I am guessing that if you take the weight off of the wheel (possibly both rear wheels) and move things around, you would be able to see or feel any play in the delta link or any bushings. With the weight on the wheels, it might be hard to tell unless it is visually obvious.
1998 V70 Non-Turbo/Auto
1993 945 Turbo/Auto
1999 S70 T5 Turbo/Auto
All U.S. market models.
All on the road and running.
PM me if you are near Philadelphia.
Has thanked: 7 times
Been thanked: 135 times
Canada
Post by scot850 » Fri Aug 23, 2019 7:57 am
Also check for broken mountings on the rear axles. I have had them rot through and the aluminum crack.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
