What to replace when doing serpentine service 2008 V70
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 3 times
Post by volvooh »
I am going to do a serpentine belt service on my 2008 V70 3.2. I am going to be replacing the A/C compressor- the clutch on the present one is toast, so I thought diving into this it would be good to replace the belt as its my wife's daily driver and with the winter approaching thought it would be good preventative maintenance. I am planning to replace the tensioner and idler pulleys, but I am curious how often the tensioners failed? I am thinking the belt and the pulleys and reusing the tensioner, but this job is such a PITA and I don't want to have to do this again...
volvooh
Re: What to replace when doing serpentine service 2008 V70
Post by volvooh »
And also does the tensioner and idler use the same type of pulley?
Has thanked: 376 times
Been thanked: 1172 times
Try putting your VIN into Volvo Web store and pulling up the part numbers to settle that debate.Sorry I don't know the 2008s well enough
Link To Volvo Glossary
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 22 times
Been thanked: 45 times
Post by xHeart »
volvooh wrote: Fri Aug 23, 2019 7:28 am I am going to do a serpentine belt service on my 2008 V70 3.2. I am going to be replacing the A/C compressor- the clutch on the present one is toast, so I thought diving into this it would be good to replace the belt as its my wife's daily driver and with the winter approaching thought it would be good preventative maintenance. I am planning to replace the tensioner and idler pulleys, but I am curious how often the tensioners failed? I am thinking the belt and the pulleys and reusing the tensioner, but this job is such a PITA and I don't want to have to do this again...
This may help a little: viewtopic.php?f=10&t=90085
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +200mi/ +322km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
jimmy57
Been thanked: 265 times
Post by jimmy57 »
The fixed wheel and the wheel on tensioner arm are the same and are common sizes used on lots of vehicles including many Fords (have no idea how that ever happened...). The tensioner is released by using a 19mm open end wrench and putting it on the crescent lug and pushing down. Now the tensioner can be locked in release position using an allen wrench or drill bit that slides into the hole facing to back of car. I think the size is 3 mm but I just grabbed a few drill bits and inserted the one that fit with least play. The power steering pump has to be removed and that is a few bolts and then remove the two 25 mm Torx screws that go through pump pulley and into the water pump drive coupler. Then the pump will lift a little and move to the side for belt to be threaded out. The compressor has to be removed and then the tensioner to get belt out. The tensioner has one bolt facing toward engine/to the RH side of car that holds tensioner assy. Take a picture o things. The braces they use are odd and you save a few attempts at starting bolts only to find out that isn't the way it goes.
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 297 times
Post by oragex »
I would also do the thermostat while there, and replace half of the transmission fluid - I think there is a v good video on Youtube with this
