1999 V70 XC - replaced my engine harness, two wires unaccounted for
Recently replaced my engine harness on my Volvo v70 xc there are two wires I can't find a connection to, ones black ones brown/ the black one is near the alternator the other is near the starter. but does not go to the starter.
Reason: improved title
- Has thanked: 2196 times
- Been thanked: 1850 times
Can you take a picture? It makes ID much easier.
- Been thanked: 4063 times
The ECT sensor wire runs near the alternator
The mAP and MAT sensors are near the starter on the induction path
Oil pressure sensor on the block near starter
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
AC compressor clutch?
Those would be grounds. One is on the subframe behind the radiator with an M6 bolt.meyersv70 wrote: 24 Aug 2019, 18:18 Ect sensor is connected, map sensor is connected. Black and brown wires have metal ends with hole in the center like a ground wire.
Worst case , attach to engine block.
- 3777 Views
Last post by packetfire
- 2087 Views
Last post by dm635
- 14 Replies
- 4608 Views
Last post by CIK7
- 13 Replies
- 2454 Views
- 34 Replies
- 9095 Views
