DO88.se Intercooler Pipe kit on S80
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
As you might have seen, the DO88.se turbo pressure pipes kit is not compatible with the S80. Even so, I bought it as it is a worthwhile upgrade over the plastic pipes. It needed some modification, but nothing too serious.
Today I finalised the built. Result: pulls a tad harder + a little bit more turbo lag.
Link to product: https://www.do88.se/en/artiklar/volvo-s ... pipes.html
Productnumber: TR-X70-S-MG-UD
The bottom pipe fitted no questions asked :) The difference is staggering.
ImageVolvo S80 2.4T DO88.se Lower Intercooler Pipe Upgrade by Andy Ramdin, on Flickr
The upper pipe needs some work though.
-The pipe needs to be sliced in half & connected with a hump hose
-You need to create a custom bracket to hold it in place
-You need some 63mm (ID) silicone hose to get it to sit in place in the angled hose
ImageVolvo S80 2.4T DO88.se Upper Intercooler Pipe (OTE) by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Hi,
looks good! may i ask a few questions?
I was considering a Do88 charge kit as well on my XC 2.5T as i have a Snaab inlet kit, on a stock turbo.
Is your car had a remap or do you run a stock engine with a stock turbo?
It does increase the air volume in the intercooler system is that ok with a stock turbo?
Is the throttle inlet tube not to close to the starter connections?
Thanks,
A
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
Antoine240bk
Found answers back when you fitted the stainless catback exhaust.
You had a BSR tuning on the car. :wink:
ndphotonl
Post by ndphotonl »
Hiya, was on a holiday. My car has not been remapped yet! Its running on stock software. You are probably a little bit confused, I have a BSR downpipe, but unfortunately no BSR software.
I have a 16T turbo on my 2.4T engine (instead of the 13T turbo), but swapped over the stock 13T wastegate on the 16T turbo, so it runs normal boost. If you skip this step, it will run in limp mode as the software needs to be modified.
Even with the 16T turbo without remap, it pulls harder as the 16T flows better than the 13T turbo, believe me :)
FlickR images
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Post by Cees Klumper »
That seems like a lot of work for not that much of an improvement? "Slice the pipe in half" to get it to fit? Jeezz!
Anyway, well done, gefeliciteerd met de job!
ndphotonl
Post by ndphotonl »
Reliability + performance upgrade, especially when you remap it. Unfortunately the slicing was needed as the kit is not designed for the S80.
FlickR images
