Did you know? 🤔
Converting Instrument Lights to LED?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
pete77gg
Year and Model: 1991 240DL
Has thanked: 0
Been thanked: 0
United States of America
pete77gg
Post by pete77gg » Sun Aug 25, 2019 10:18 pm
Hi all, working on my 1991 Volvo 240DL 4Dr Sedan and hoping you can assist with a 2 part question concerning LED conversion of my instrument cluster illumination lights (the 2 bulbs that light up the clock, speedo, temp & fuel guages from above.
1) Is there a way to convert the existing Flosser 110736 type instrument bulbs https://www.ipdusa.com/products/4827/1 ... pcQAvD_BwEImage
If so, bulb type and brief description of the swap / install would be helpful.
2) If not, anyone remove the stock bulbs and hardwire in LEDs to replace the old bulb types? If so, type, where you bought and description of the install would be much appreciated.
Also side question - is there an easy (non-destructive) way to remove the clear plastic in front of the gauge faces?
Thank you!
Pete
Year and Model: 2001 V70
Has thanked: 0
Been thanked: 14 times
Re: Converting Instrument Lights to LED?
Post by volvolugnut » Tue Aug 27, 2019 5:43 pm
Some thoughts on change to LED instrument lights:
1. Most bare LED's that I have seen are not 12 volt. More like 5 volt. They would need a properly selected resister to drop 12 volts to their needs.
2. LEDs are polarity sensitive. You would need to figure out how to match polarity or the diode (the D in LED), would just go POP and not work again.
3. To make your own from LED and resister, you would need to make it fit in the same space as the old bulb.
Do you want to have a light that last a long, long time or are you wanting to change color of the instrument display? Seems a lot of trouble to me, but should be possible. You may find something in a general google search.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
