Hello,
I have Volvo S80 MY00 TDI with multifunction steering wheel - cruise control, volume etc...
But it doesnt have backlight on the buttons. Is it some way how to adapt it to backlight function.
I tried to get steering wheel ring with connectors for buttons with backlight and buttons. But I found a problem under the ring. It is not compatibile with PCB under.
Does anyone have any advice?
Thank you
Volvo S80 MY00 backlight on the steering wheel
- June
- Has thanked: 523 times
- Been thanked: 261 times
My 2004 are backlit to match dash buttons. I think my 2002 S80 buttons were too though I can't 100% remember. So maybe install a set off a 04 or perhaps a connection is bad on yours that powers the backlighting? If I think of it tonight I'll take a picture. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Hello thank you for response. But there is a problem. I tried to connect buttons from MY2004 with backlight, but the ring under the steering wheel is for 2 pins airbag - first problem. Second problem is under the new ring. There is a connector in PCB for ring which is not compatible.
So... maybe there is a option, but even with that PCB replacement, but I dont know what is under.
- June
So the 2000 never were lit then. My father's last couple of Town Cars had the lights under the window switch go out variously. I was hoping for your sake maybe the lights had gone out. Thus far all dash/switches, both door and steering wheel/and console still work. Being as Ford same era and Ford owning Volvo in 04 either I am lucky or Volvo just did it better. JuneTarkin wrote: 02 Dec 2019, 10:40 Hello thank you for response. But there is a problem. I tried to connect buttons from MY2004 with backlight, but the ring under the steering wheel is for 2 pins airbag - first problem. Second problem is under the new ring. There is a connector in PCB for ring which is not compatible.
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- June
Here are the things that light up on my 2004 S80 I didn't bother photographing the rear doors and passenger door switches but they light too. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
spunkymonky
- Year and Model:
The no backlights on the steering wheel drove me nuts so I bought an 04 wheel and had the same issue with the wiring harness not being compatible so I pulled the lit buttons out of the 04 wheel and installed them in the 00 wheel, grabbed power from another source inside the wheel. I think maybe the radio control and lit the leds that way. It was a bit messy but easy and it's been functioning now for 9 years no issues.
- 590 Views
Last post by mrbrian200
- 1268 Views
Last post by anothevolvofan
- 920 Views
Last post by RickHaleParker
- 313 Views
Last post by rntaboy
- 1227 Views
Last post by WillieEvans
