IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
1998 V70 T5; problem hot starting & occasional brief power loss at speed
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Re: 1998 V70 T5; problem hot starting & occasional brief power loss at speed
Post by clifford06 »
If injectors spray when hot , What could be my next point of focus ? ECU ?
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 379 times
Been thanked: 1185 times
If it fires in ether, and the injectors are delivering fuel, the fuel delivery amount is wrong.
I think you need an oscilloscope to confirm the injector pulse ( more accurately , how long the ECU isnpulling the injectors to ground
An ECU swap is the Mossberg method if you can’t get a scope , but you are getting close, not much else left
Send me your coordinates, TX travel planned soon.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
clifford06
Dallas. Been busy with work and family . Could injector relay act just like a fuel pump relay ? Meaning , could it stop working or cause a stall when hot ?
clifford06
Also , while doing research, I saw something about air pump relay having the same " value " as the injector relay . I guess this means they are interchangeable ? If so , I have a few relays from a salvage run that I could try . Thoughts and helping opinions always welcomed !
misha
Year and Model: '97 850 2.5 20v
Has thanked: 59 times
Been thanked: 163 times
Post by misha »
They are NOT interchangeable and also visualy not the same.
Yes...main fuel injection relay could make problems when it becomes hot....just like any other relay.
Try to swap it with a used one and see if problems go away.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: 850, S/V70, 06 S60R
Has thanked: 112 times
Been thanked: 328 times
Post by erikv11 »
erikv11 wrote: Tue Sep 17, 2019 5:41 pm There's also the gray fuel injection main relay up under the radiator - or maybe that relay is not used on a 98? My 98 is not here or I would check. Someone else will remember.
It's basically guaranteed to be an electrical/electronic part, that when it heats up the resistance gets too high. V = IR so currrent drops and the component stops working and the car stops working. Could be a relay, sensor, or a critical wire that is thin or poorly connected.
:mrgreen:
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
gone: '96 NA 850 210k, '98 NA V70 182k
clifford06
Thanks for the reply .I'll make a salvage run this weekend. You quoted from the same thread I read .
clifford06
Hello ! Today I spoke with local Volvo dealer about price of a injector relay ( local salvage yards are bare of S70s ), and the part number matches main relay in main fuse box. I called back and was emailed a schematic showing the location was in the main fuse box , not under radiator cover . Only thing on radiator cover is cooling fan connections.
From the pic , it seems it goes in slot #2 in fuse box , which is labeled Air Pump on the underside of fuse cover . I have no fuse there , never have . Maybe that was to show general location. I think , maybe my problem is the main relay itself ? I have a matching relay from previous salvage run that I'll put in and see what I get . Any input is welcomed !
clifford06
Swapped main relay after getting car to temp, and still same result . I'll swap cam sensor next .
Post by erikv11 »
Yeah, I didn't think the 98 had the relay at the radiator. This is a sticky one hang in there ...
'96 855 NA, 145k
'06 S60 R, 167k
