Dear community
Recently my car's engine started to produce a strange popping, crackling, clicking noise, whenever I start it. After a while the engine just stops, especially if the air conditioning is also turned on. This noise kills the engine. I'm really not sure what's causing the problem. But the car is in no condition to travel anywhere like this.
I would appreciate any help to figure out the cause or a solution to fix the problem.
My car is a Volvo 850 Sedan made in 1993.
Thanks in advance !
Here are two videos to show the sound I'm talking about:
Starting up the engine:
With air conditioning turned on:
Help needed with Volvo 850 engine popping noise Topic is solved
hunterhuni
- Year and Model: 1993 Volvo 850 GLT
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Sounds horrible. could it be bad ignition components? when did you replace the wires, plugs, rotor etc.? Also, the startup sounds creepy as well. Which would make me think of the ignition as well.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Try removing the serpentine belt and seeing of the noise stops. It does not sound good, but could just be a bad accessory
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
Look at how the engine vibrates when it makes the noise. Is that knocking/misfire? Burned valve? It doesn't sound like piston slap. Could be a weird sounding rod knock.
The serpentine belt is long and it takes several rotations of the engine for it to hit the same point in the belt.
Does the noise go away if you rev the engine? Does it go away when the engine is warm?
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
hunterhuni
Well, to be honest it's been a while since I replaced the components. But the ignition is working fine I checked it. It feels more like if something is jamming the engine.Clemens wrote: 28 Aug 2019, 13:34 Sounds horrible. could it be bad ignition components? when did you replace the wires, plugs, rotor etc.? Also, the startup sounds creepy as well. Which would make me think of the ignition as well.
hunterhuni
I will try it on the weekend, thanks for the suggestion. Hopefully it's just a bad accessory somewhere.abscate wrote: 28 Aug 2019, 14:06 Try removing the serpentine belt and seeing of the noise stops. It does not sound good, but could just be a bad accessory
hunterhuni
It feels more like something is jamming the engine when it tries to roll. Sometimes it goes away when reving, but it comes back in idle every time. First I'll try to remove the serpentine belt this weekend, let's see if that helps.callahanoffroad wrote: 29 Aug 2019, 06:28 Look at how the engine vibrates when it makes the noise. Is that knocking/misfire? Burned valve? It doesn't sound like piston slap. Could be a weird sounding rod knock.
- Clemens
At idle a bad sparkplug or wire can actually lead to heavy cutouts in these cars. they usually start cutting out in humid conditions, but not necessarily. almost like the engine wants to stall.hunterhuni wrote: 29 Aug 2019, 09:56Well, to be honest it's been a while since I replaced the components. But the ignition is working fine I checked it. It feels more like if something is jamming the engine.Clemens wrote: 28 Aug 2019, 13:34 Sounds horrible. could it be bad ignition components? when did you replace the wires, plugs, rotor etc.? Also, the startup sounds creepy as well. Which would make me think of the ignition as well.
but then, maybe it is something with one of the accessories. before you remove the belt, look up on all the creative super cheap serpentine belt tools members of this forum came up with.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
That sounds like crossfire to me. Cap, rotor, wires and plugs to get you to where it can be diagnosed. You may find that it went away when you do a tune up.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
hunterhuni
Okay, I managed to figure it out. I changed the head gasket, and two of the wires that go to the spark plugs. Two of the engine cylinders weren't working because of that. Now it runs like butter.
Apparently it wasn't that big of a problem. Thanks for the help, and suggestions. Drive safe
- 2069 Views
Last post by sjlarcom
- 61 Replies
- 10680 Views
Last post by zakmuh
- 1448 Views
Last post by oragex
- 1584 Views
Last post by chris11211
- 565 Views
Last post by GlennG2759
