2006 V70 rear swaybar endlinks ? Topic is solved
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
I just replaced my front endlinks on '06 V70 NA FWD with Meyle HD kit. I went to do the rears and I can't find them. I know this may sound like a stupid question but is there a possibility there was some kind of design change in late 2006 or it didn't come with a rear swaybar. Thanks in advance. G.G.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
They sure should be there. Unless the PO removed them. Though I don't know why anyone would.
Rear sway bar end links are available for 2006's.
Did your new fronts have torx end pockets on the studs? Or just hex?
Personally, I get the German ones with the torx end pockets - less likely to strip out when it comes time for removal.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- GlennG2759
I've been some doing some research and there seems to be a couple of different versions of rear suspension (L5,L6). There didn't even seem to be enough room for swaybar, although there was an eyelet the right size for an upper mount on what I would call an upper control arm (maybe?). I doubt PO took it out (original owner averaged under 8k year, Volvo service, garage kept). Meyle links seem to be quality product, couple mm's thicker, no torx or allen anti-spin, flats for wrench on ball side. Only time will tell. Thanks for input.
- - Pete -
Bizarre, Sorry if I mislead you. I have yet to work on an NA FWD only P2.
Whether you look up the B5244S or B5244S6 the same end links are populated.
So there is NO sway bar present at all?
Edit: I just spent a couple hours under our 04 V70AWD today and was debating on replacing the rear sway bar due to its corroded state. Links looked perfect.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
My 2003 S60 non turbo has them
- GlennG2759
Nope, no swaybar, hence no endlinks. I noticed when I ordered them from Fcp (will they fit my car), there was an L5 designation wonder if that means anything. Was this an option in 2006 or was somebody at the factory having a bad day. The eyelet on upper rear control arm where I think the endlink would go shows no scarring on either side that would indicate an endlink was bolted or went through it. Also no sign of damage or scrapes underneath, that somebody would've said the heck with it I'll take it out. Also if some of this particular model came without the swaybar, what was the deciding factor.
Random? Weird, huh?
Random? Weird, huh?
- - Pete -
Well lucky for you, one less thing to have to replace.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- GlennG2759
Would he be worth putting one in, I would imagine all the mount are there. Noticeable ride difference?
- 2131 Views
Last post by j-dawg
- 119 Views
Last post by DavidE7
- 2181 Views
Last post by E Showell
- 1309 Views
Last post by oragex
- 437 Views
Last post by precisionguesswork
