Please tell me if these steps sound correct:
1) After the wheel is removed, loosen the two square ended screws (top/bottom) on the caliper.
2) Pry off the wire clip from the caliper.
3) Wiggle the old pads out from within the caliper.
4) Depress the caliper piston back in with a "C" clamp or other device.
5) Grease the back side of both new pads with brake grease.
6) Insert the new pads into the caliper.
7) Re-install a new clip.
9) That's it!
**Regarding bullet #7, does that clip just get pressed back into place or do I have to spread it a little with a screwdriver?
Thank you gentlemen.
