Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
Replace ball joints with control arms? ('04 XC)
- BlackBart
- Has thanked: 39 times
- Been thanked: 30 times
Morning Gents and Ladies -
Is it mandatory / advisable / a good idea to replace the ball joints when replacing front control arms on the XC? I have some clunks in the control arms, and I see some rubber failure looking underneath. I've been waiting for a sale to get the heavy duty ipd arms.
The ones on the car are fairly new - I have the PO receipts. Must have been cheap aftermarket as they have failed very early. So that means the ball joints aren't very old either.
Here are the cool new ipd ball joints in stainless with better boots...
https://www.ipdusa.com/products/16567/1 ... 641-274548
What's the group's advice?
Thank you -
Thank you -
1994 850T wagon
Is it time for a 1964 122 wagon?
1994 850T wagon
- Year and Model: 1998 V70 T5/S70 T5M
- Has thanked: 0
- Been thanked: 3 times
Re: Replace ball joints with control arms? ('04 XC)
Yes, might as well while in there, tie rods and endlinks, too. I would go with Lemforder control arms, ball joints and tie rods. Meyle HD endlinks (sway bar links) are a good economical choice. FCP of course.
- oragex
- Year and Model: S60 2003
- Has thanked: 89 times
- Been thanked: 211 times
For the ball joints get the Lemforder ones. They make the genuine ones for Volvo
- Antoine240bk
- Year and Model: XC70 2.5T-2006
- Has thanked: 10 times
- Been thanked: 14 times
Yes you might if you don't want to come back later. I did the whole front end at the same time with OEM parts, lemforder for the end links. OEM for the Inner & Outer tie rods. these ipd ball joints looks good too!
A fitting tool with two M8x120mm screw to sit the ball joints, is very handy.
Use a impact gun if it is too rusty, i broke a screw in the left knuckle, hopefully i had a extractor...
Volvo XC70 2.5 T AWD P2 BVA B5254T2 12/2005 Four-C EX : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -Gpl - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
- BlackBart
No real rust, it's surprisingly clean.
Thanks for the advice - do it once, do it right........
1994 850T wagon
1994 850T wagon
- Has thanked: 0
- Been thanked: 111 times
Most people would say:
- Ball joints: Lemforder as mentioned.
- Control arm, get the arm with bushings already in there to avoid pressing in bushings (you need a heavy-duty press to push the new bushing in if you buy control arm w/o bushings!). Just buy the Volvo control arms which already has the bushings installed. It is a bit more expensive but they should last some 100K miles.
- BlackBart
The info I've read is that the Volvo control arm bushings are recycled rubber, and it's not sticking to the metal the way it should. I'm not sure which off-brand, but the PO's control arms lasted less than 20,000 mi. The ipd heavy duty arms have new rubber and are supposed to last.
FCP has the Lemforder arms but don't say anything about rubber materials. Their big sale is $5 off each, whee. I do have plenty of Lemforder parts in other cars, so I agree they're top quality.
1994 850T wagon
1994 850T wagon
- Has thanked: 0
I don't know if Volvo has changed the bushing formulation, but the control arms in my 2005 XC90 2.5T with 120K are still original.
They (control arms as a whole) need to be replaced soon, but the bushings in Volvo Genuine control arm have been very good.
- oragex
I'm running now on genuine replacement bushings - pressed in myself. The rubber is very stiff and has like sort of 'glitter' to it. Will update in case I have problems in the long term.
- vtl
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 42 times
I think it is commanded by EU's ecomafia to use a portion of recycled rubbish in replacement parts. I had both Lemforder and Volvo bushings pressed in myself, both last for long time. Volvo ones are 75k miles old now, and they are still good. Not new, but good. I take my wagon into interesting places, too.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
'04 V70 lower ball joints, or complete control arm?
by Faust » Thu Apr 07, 2016 8:38 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 2 Replies
- 293 Views
Last post by Faust
Thu Apr 07, 2016 8:54 am
Ball joint puller needed for front lower control arms?
by jefflamonica » Thu Mar 03, 2016 3:16 pm » in 240, 740, 760, 780, Bertone, 940, 960, V90, S90 - 3 Replies
- 967 Views
Last post by apollokid
Mon Apr 18, 2016 12:41 am
Air hammer for removing ball joints
by veektor » Tue Apr 09, 2019 12:21 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 2 Replies
- 169 Views
Last post by veektor
Wed Apr 10, 2019 8:23 am
2006 V70 ball joints
by GlennG2759 » Wed Aug 21, 2019 9:47 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 3 Replies
- 107 Views
Last post by ionianp2
Wed Aug 21, 2019 2:23 pm
