Strut - 1994 850 wagon - clunk sound, now it's leaning
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Hi Guys, I've got a dilemma.. I had both struts replaced. Afterwards I drove 4 miles stopped and parked. There was a clunkand now it's leaning. I know it's lower because after this I had to put new sway links on cause the ones I ordered didn't fit when the job was done.when we put it on a 4 legged ( whatever you call it ) ( : hydraulic lift it was lower getting that side of the leg lift up under the car. What the heck happened? Why did it fall? A friend said its probably the clamp wasn't tight and the spring dropped in the cup spring. I don't know. I do know if it has to be taken off again I have to get all new mount nuts.or could I have gotten a bad strut. There Sachs original. What do you guys think is going on? Thank you❤
Reason: improved title
Take some pictures of the struts with some light so we can see detail and maybe
The cheap strut parts are the Devils tin snips, tempting you with their price, only to break on the trip home.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Either a spring failed or the top strut mount broke. Open the hood to check the latter. But, considering the age of the car, I would lean towards a broken spring. If this is the case, you will need new springs on both sides.
Klaus
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Did the spring seat bust through? Usually hits the hood.
- Has thanked: 311 times
- Been thanked: 817 times
"Usually" hits the hood??? I've heard of that a couple times but never actually seen it happen, And I've seen a couple dozen busted. P80 spring seats.
Would be interested to see pics of the strut hitting the hood.
- ZionXIX
Maybe it's more rare than I thought but it happens. I guess it's more due to installer error.erikv11 wrote: 31 Aug 2019, 18:43"Usually" hits the hood??? I've heard of that a couple times but never actually seen it happen, And I've seen a couple dozen busted. P80 spring seats.
viewtopic.php?t=53566
loveMy850
Its drivable. I'm in another pickle so I've been so busy So Sorry not getting back,a friend rolled his truck and now I'm out in the middle of nowhere, no wifi only data had to get my phone turned on and change phones finally a girlfriend came over to give me a break away I'm at paneras, yes one big hassel. anyway its drivable, just not my baby, shoot I should have left old struts on. anyway when I get time,I hope this evening I have to get back on site and fill you guys in, she runs so rough, not good, not good at all, and get on this, I appreciate all you guys, I'm so distraught right now, and worn the H out! I know its labor day and everyone will be out having a good time, I hope you all do! I know I'm not going anywhere!, Gotta take care of a friend, its who I am, but I need your help guys...... ok, well Happy Labor Day everyone.. B safe out there.
duplicate post deleted
Hang in there, we'll be here when you get back around to it!
Thanks for posting that up. That's one junky spring seat in that example - those were by Gabriel.
It’s fine to chat back and forth on MVS but please do not text talk.
See posting guidelines above.
Keep sentences simple with subject , verb , object, and punctuation.
- 3340 Views
Last post by yamaboosh
- 1731 Views
Last post by precopster
- 2301 Views
Last post by MadeInJapan
- 2531 Views
Last post by AVOIT17
- 11 Replies
- 4644 Views
Last post by erikv11
