Ok,
The engine blew on the 2001 S60 with 91k miles. Looks like prev owners were driving too long with a bad ECM dumping fuel into the crankcase. Engine oil pressure dropped while cruising at highway speed "low oil pressure stop asap" message on dash with oil light on and i shut off immediately and the cam cover had blown off!! Sludge found inside. Need to know what years/models motors will fit. It's a 2.4 turbo.
Dan
2001 S60 2.4 T which motors fit?
goldmandan
- Year and Model: 1999 S 70, 2000 V70
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
The 6th and 7th characters in the VIN give you the engine family code. You want yours to match the donor car.
https://www.volvotechinfo.com/index.cfm ... vinDecoder
You can be a lot more flexible if you are willing to make a head swap, but a used engine with warranty should be about $500, so unless time is critical ,wait for the match from 2001-2004 model
- 3191 Views
Last post by mrbrian200
- 655 Views
Last post by fireman0977
- 17731 Views
Last post by combatkarl
- 1812 Views
Last post by vtl
- 915 Views
