Within the last few days I have had the 150000 mile service done and a new alternator installed. After driving the car for 30 minutes, the car will not start, the dash is blank. After a jump start, the car runs fine, There are no check engine lights on or batter lights on.
I had the battery and the charging system tested and all passed.
Car is dead in driveway and will need key to open door and open hood for a jump.
Thoughts?
Dash goes blank and needs a jump to start
sounds like you have a parasitic battery draw. hook a test light and verify if there is current flowing. Then pull each fuse until it goes out. That should identify. I had same issue, turned out it was the electric E-brake. Good luck
- 608 Views
Last post by MsVolvos802000
- 597 Views
Last post by bubisamongus
- 2166 Views
Last post by smacknab
- 1249 Views
Last post by Derbyrunner
- 2219 Views
Last post by alschnertz
