IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2007 S80 OE Ignition Coil - OE manufacturer?
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
2007S80
Year and Model: 2007 S80
Has thanked: 0
Been thanked: 0
United States of America
2007S80
Post by 2007S80 » Sun Sep 01, 2019 2:14 pm
Hi all, my first post.
Do you by chance know who the OE manufacturer is for ignition coils on a 2007 S80 with the 3.2 engine?
I recently purchased an S80 3.2 with 140k and the #6 ignition coil recently failed. The Volvo dealer replaced all the plugs and the #6 coil only. Just looking to save a few bucks while replacing the other 5 coils.
Thanks!!
Reason: improved title
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 25 times
Been thanked: 43 times
pgill
Re: 2007 S80 OE Ignition Coil - OE manufacturer?
Post by pgill » Tue Sep 03, 2019 5:41 pm
To answer your question: Denso
I did recently buy a coil but it just sits on my shelf.
I own two 3.2s and so far I’ve replaced zero coils
There is evidence that suggests that coil failures are related to a Thermostat failure and/or worn spark plugs
Pictures of the coil pack
Good luck
Paul
2007S80
Has thanked: 0
Been thanked: 0
2007S80
Post by 2007S80 » Wed Sep 04, 2019 8:36 am
Thanks Paul! I recently purchased a 2007 S80 3.2 with 140k miles. I put another 3k miles on it in a month and then had the #6 coil fail. Apparently the previous owner, despite doing all other maintenance at a Volvo dealership, didn’t do the coils. The dealership replaced the #6 coil and all of the spark plugs.
I ended up just buying five more Volvo coils through FCP Euro. My brother owns his own repair shop so I’m going to have him throw them on as well as a new Fuel Pressure Sensor.
pgill
pgill
Post by pgill » Wed Sep 04, 2019 9:28 am
Welcome to the S80 P3 team.
I bought a 2010 S80 3.2 almost a year ago for my Son to drive to work.
I've owned since new a 2008 LR2 (a Land Rover based on the Volvo drive train)
As for the Thermostat it is not considered a maintenance item by Volvo and it is know to fail in about 10 years or 100K miles in a mild climate (sooner if you live somewhere tropical)
I would be shocked if your thermostat is original and not broken. (Note: the failed thermostat may not set a check engine light, my S80 thermostat was broken but there were no symptoms)
If you have the maintenance records from the previous owner then you can use that to determine what needs to be looked after.
Here are two links that might interest you
Maintenance items and common failures (including what the factory forgot)
https://www.freel2.com/forum/topic32504.html
Details of everything that I did for my S80 since I bought it a year ago
https://www.matthewsvolvosite.com/forum ... 31&t=87687
One last thought, I highly recommend that you use Denso iridium spark plugs
For my LR2 I installed
Denso (5344) IKH20 Iridium Power Spark Plug at 50,000 miles
Denso (5344) IKH20 Iridium Power Spark Plug again at 100,000 miles
For my S80 I installed
Denso (5344) IKH20 Iridium Power Spark Plug at 125,000 miles (when I bought the S80)
The next time I change plugs I will be using
Denso (4704) IKH20TT Iridium TT with a .040" Gap
The TT (Twin Tip) has two fine wires.
Good Luck
Paul
2007S80
Has thanked: 0
Been thanked: 0
2007S80
Post by 2007S80 » Wed Sep 04, 2019 9:56 am
Paul, thanks for the tips! The dealership put Volvo spark plugs in so I’m good to go there (I would have preferred to purchase them on my own as they were marked up significantly).
I wish I had the technical know-how to work on my car myself, but am glad my brother lends a hand.
