Hi all, my first post.
Do you by chance know who the OE manufacturer is for ignition coils on a 2007 S80 with the 3.2 engine?
I recently purchased an S80 3.2 with 140k and the #6 ignition coil recently failed. The Volvo dealer replaced all the plugs and the #6 coil only. Just looking to save a few bucks while replacing the other 5 coils.
Thanks!!
Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
2007 S80 OE Ignition Coil - OE manufacturer?
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 13 times
- Been thanked: 27 times
Re: 2007 S80 OE Ignition Coil - OE manufacturer?
To answer your question: Denso
I did recently buy a coil but it just sits on my shelf.
I own two 3.2s and so far I’ve replaced zero coils
There is evidence that suggests that coil failures are related to a Thermostat failure and/or worn spark plugs
Pictures of the coil pack
Good luck
Paul
Good luck
Paul
- Year and Model: 2007 S80
- Has thanked: 0
- Been thanked: 0
Thanks Paul! I recently purchased a 2007 S80 3.2 with 140k miles. I put another 3k miles on it in a month and then had the #6 coil fail. Apparently the previous owner, despite doing all other maintenance at a Volvo dealership, didn’t do the coils. The dealership replaced the #6 coil and all of the spark plugs.
I ended up just buying five more Volvo coils through FCP Euro. My brother owns his own repair shop so I’m going to have him throw them on as well as a new Fuel Pressure Sensor.
- pgill
Welcome to the S80 P3 team.
I bought a 2010 S80 3.2 almost a year ago for my Son to drive to work.
I've owned since new a 2008 LR2 (a Land Rover based on the Volvo drive train)
As for the Thermostat it is not considered a maintenance item by Volvo and it is know to fail in about 10 years or 100K miles in a mild climate (sooner if you live somewhere tropical)
I would be shocked if your thermostat is original and not broken. (Note: the failed thermostat may not set a check engine light, my S80 thermostat was broken but there were no symptoms)
If you have the maintenance records from the previous owner then you can use that to determine what needs to be looked after.
Here are two links that might interest you
Maintenance items and common failures (including what the factory forgot)
https://www.freel2.com/forum/topic32504.html
Details of everything that I did for my S80 since I bought it a year ago
https://www.matthewsvolvosite.com/forum ... 31&t=87687
One last thought, I highly recommend that you use Denso iridium spark plugs
For my LR2 I installed
Denso (5344) IKH20 Iridium Power Spark Plug at 50,000 miles
Denso (5344) IKH20 Iridium Power Spark Plug again at 100,000 miles
For my S80 I installed
Denso (5344) IKH20 Iridium Power Spark Plug at 125,000 miles (when I bought the S80)
The next time I change plugs I will be using
Denso (4704) IKH20TT Iridium TT with a .040" Gap
The TT (Twin Tip) has two fine wires.
Good Luck
Paul
Good Luck
Paul
- Has thanked: 0
- Been thanked: 0
Paul, thanks for the tips! The dealership put Volvo spark plugs in so I’m good to go there (I would have preferred to purchase them on my own as they were marked up significantly).
I wish I had the technical know-how to work on my car myself, but am glad my brother lends a hand.
P80 P2 Coil on ignition - Replacing ignition coil connector housing
by prwood » Wed Nov 15, 2017 6:49 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 8 Replies
- 1463 Views
Thu Nov 16, 2017 7:13 am
Coil replacement Manufacturer?
by Mr. Detail » Sat Nov 24, 2018 8:02 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 20 Replies
- 761 Views
Last post by erikv11
Tue Dec 04, 2018 8:06 am
2007 v8 ignition coil harness replacement
by xiphosm3 » Sun Sep 09, 2018 4:55 pm » in Volvo XC90 Forum - 6 Replies
- 315 Views
Last post by RickHaleParker
Mon Sep 10, 2018 2:25 am
Best bush manufacturer?
by SS2115 » Mon Dec 28, 2015 4:19 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 2 Replies
- 413 Views
Last post by misha
Mon Dec 28, 2015 5:05 pm
