01 v70 PCV system: drive without it?
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
I have determined my car needs a new PCV system. I bought the kit. But which parts actually should be replaced? Just hoses or entire thing with breather box? I understand the PCV system is for emissions, per what Robert 'DIY' Spinner says. I understand that a clogged PCV system can cause the front main seal to bust (rarely i heard) and the rear main seal to bust. But what would happen if i drove it with no PCV system? Its a NA (base model) engine.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1609 times
Been thanked: 4065 times
You can route they crankcase gasses to the road with a tube , otherwise your engine bay gets all oily.
The bad part is you will suck dirt and grit into your engine every time you lift your foot, so that’s hard on the oil and thus the bearings and expensive bits
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Your soul will become enslaved as a concubine to the myriad of deceased Prius owners who’ve helped all ecosystems & humanity with their eco-mindedness.
If you already bought all the components, just change it all out. If it’s plugged, you will have oil leak(s), best case scenario. Worst case, you’ll lose oil PSI completely. <— This is NOT a good thing.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
