Did you know? 🤔
96, 850 N/A hesitation issue
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 19 times
Been thanked: 3 times
United States of America
Danonly55
Post by Danonly55 » Sun Sep 01, 2019 9:32 pm
I searched the forum and found nothing for my particular model, The car started hesitating at idol and during acceleration. The red arrow showed up on dash but then went out. Car still didn't feel right. Yesterday I reset the #2 O2 sensor code and drove it about 3 miles with no issues. Any Ideas where I should start ?
1996 Volvo 850 sedan base
1980 Mercedes benz 300sd " Shotzie"
1997 Ford f350 7.3
Life is tough, but it's tougher when your stupid'
" John Wayne
greg850r
Year and Model: a long list
Has thanked: 2 times
Been thanked: 8 times
greg850r
Re: 96, 850 N/A hesitation issue
Post by greg850r » Sun Sep 01, 2019 9:42 pm
Start with looking for vacuum leaks.
These users thanked the author greg850r for the post:
Danonly55
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
Has thanked: 56 times
Been thanked: 193 times
Post by erikv11 » Sun Sep 01, 2019 10:04 pm
Good call from greg850r. Replace those crumbling, 20 year old rubber vacuum hoses ...
A guide: viewtopic.php?t=65002
'96 855 NA, 140k
'98 S70 NA, 210k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 280k
'06 S60 R, 160k
Has thanked: 200 times
Been thanked: 647 times
Trinidad & Tobago
Post by abscate » Mon Sep 02, 2019 6:33 am
Every 30,000 miles you should evaluate ignition parts on a P80
Spark plugs (replace if they are Cu type, regap expensive type where possible)
wires
Coil
Distributor cap
Rotor
Those last two should be shiny copper clean and bright on all metal parts
Danonly55
Danonly55
Post by Danonly55 » Mon Sep 02, 2019 8:36 pm
wires
Coil
Distributor cap
Rotor
I have replaced all ignition parts less than 2k miles ago, I ordered a PCV system kit today, It's due anyway.
1997 Ford f350 7.3
" John Wayne
Danonly55
Danonly55
Post by Danonly55 » Mon Sep 02, 2019 8:45 pm
A guide: https://www.matthewsvolvosite.com/forum ... hp?t=65002
Sweet link with pics , Thank you !!
1997 Ford f350 7.3
" John Wayne
Danonly55
Danonly55
Post by Danonly55 » Mon Sep 02, 2019 9:02 pm
Ok I just hooked up the OBD reader and started the car, The code it's throwing is 0102 not sensing air flow, looks like I may need a MAF sensor also?? Car did not want to stay running, Had to feather gas peddle to keep running.
1997 Ford f350 7.3
" John Wayne
Post by erikv11 » Mon Sep 02, 2019 10:38 pm
p0102 may be a bad MAF or very commonly, a vacuum leak. Usually the rubber elbow behind the corner of the intake manifold, on the passenger side. Called "line 3" in that link up above.
To test the MAF, unplug it with the car off, then start it up. Without a MAF the ECU will go into default air:fuel mixture, running a little rich, but should run just fine if the MAF is the problem. This will set a MAF code which you'll need to reset after the test.
'96 855 NA, 140k
'06 S60 R, 160k
Danonly55
Danonly55
Post by Danonly55 » Tue Sep 03, 2019 8:30 am
Ok great I will give that test a try and also check the #3 vac line. I'll keep ya posted. Thank you
1997 Ford f350 7.3
" John Wayne
Danonly55
Danonly55
Post by Danonly55 » Tue Sep 03, 2019 9:08 am
I performed the test, and it acted as you said. The #3 vac line looked and felt in good condition.
1997 Ford f350 7.3
" John Wayne
