Can anyone confirm the correct Bosch part number for a fuel pressure sensor for a 2007 S80?
Rock Auto shows the part number to be 0261230110.
FCP Euro shows the part number to be 0261230238.
Thanks!
2007 S80 Fuel Pressure Sensor
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
When I was researching this question I decided to buy
BOSCH 0261230238
I did buy this sensor because of failures experienced by others but I haven’t installed it yet
I own two 3.2 and the sensor will fit both
2010 S80
2008 LR2
The engine is the same for both vehicles
If you do a google search of images you will see that the other sensor has two mounting holes and the one I bought only has one
It’s my understanding that either sensor will fit.
Good luck
Paul
BOSCH 0261230238
2010 S80
2008 LR2
Good luck
Paul
- pgill
More information about the sensors
https://www.bosch-automotive-catalog.co ... 0261230110
https://www.bosch-automotive-catalog.co ... toLoad%3D1
Steve H
- Year and Model: 2008 S60 2.5T & XC70
- Has thanked: 6 times
- Been thanked: 10 times
My 2008 has the 0261230110 sensor on it and my son's 2008 Volvo S60 2.5 also has the 110 sensor on it. The extra "mounting hole" is actual for a wire harness clip for the S60 application where my XC70 3.2 does not use that hole.
Steve H
I questioned FCP Euro about their application part number and I told them what was on my car and their response if that my XC70 3.2 has the wrong sensor on it to have the Bosch part number ending in 110. They said it should be the one ending in 238.
- pgill
Steve
It’s my understanding that the sensors are functionally identical
But as you pointed out the one sensor has some extra features for mounting the wiring harnesses to
Thanks
Paul
Thanks
Paul
- 16134 Views
Last post by Richard99
- 3511 Views
Last post by CodyS80
- 7954 Views
Last post by adrian22
- 1093 Views
Last post by rtoomey641
- 20 Replies
- 13349 Views
Last post by oragex
