And she knows
I tried to tie in a dashcam into dome light wires, found power and ground, it worked fine, looks like I tied into the airbag wires and killed sunroof.
I tried reset and battery off and code reader erase, nothing is working.
Her is the reset I used once before that worked
1)Close all of the doors and bonnet.
2)Key in position II engine not running.
3)Hold both the driver window and passenger window switches in the
driver door panel in the closed or up position for 5 to 8 seconds after the
windows are closed.
4)Release buttons.
5)Remove the ignition key.
6)Operated the remote twice. lock/unlock lock/unlock
I also tried the hold sunroof closed button for 30 secs, then release and hold again for 4 secs
HELP Big Problem WIfes sunroof broken I did it
- 2549 Views
- 2003 Views
Last post by dudeitssm
- 11 Replies
- 2139 Views
Last post by rdwhittaker
- 1426 Views
Last post by hanzbe420
- 756 Views
Last post by Sufbug
