Hello all, I am new to the forum and have a question that I have not been able to find an answer to. Therefore I am asking for some knowledge that goes beyond my own.
I have a 2006 XC90 Ocean Race 2.5t AWD. A little while ago I bought replacement rear knuckles with wheel bearings from a newer 2011 XC90. They must have been from a V8 because after removing a noisy hub to replace it I found that it was different than the original in that it lacks the little white plastic teeth that sit over the magnet on the inside of the hub. I had replaced the hub with an older one to figure out which bearing it was that was bad. I immediately got a abs message and a brake system failure message.
I am guessing that the magnetic pattern must differ between the 2.5t and V8 hubs that would cause the messages? What do I do about the wheel bearing needing replacement? Do I get one for a V8 to match the other side? Can't really afford to replace them both right now.
Please any advice would be appreciated.
Rear wheel bearing swap and abs light
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
I'm not aware of any powertrain or model year differentiation with the rear axle (PN 36000930 exch) or the rear wheel bearings (Left- PN 31340099, Right-PN 31340100). White plastic teeth missing, got any photos?
IIRC, the ABS sensor ring for the rear is located within the bearing assembly itself.
This link has some visuals- https://forums.swedespeed.com/showthrea ... -of-photos
- 528 Views
Last post by volvooh
- 2735 Views
Last post by 57gretsch
- 2573 Views
Last post by songzunhuang
- 1919 Views
Last post by sleddriver
- 2402 Views
Last post by [email protected]
