Loosen any lug nut by putting the jack underneath the lug wrench or breaker bar. Then jack up the lug wrench.
I tried this only after bending my original lug wrench AND bending a five foot cheater bar.
Dale L
Loosen ANY lug nut
If you really think they got torqued to 500 ft lbs replace them all.
If they were just stuck with corrosion, they are fine. In that case, 30 seconds with a propane torch is a much nicer way to remove frozen fasteners.
- dalel
- Year and Model: 1998 V70
- Has thanked: 29 times
- Been thanked: 7 times
Good to see you...abscate wrote: 03 Sep 2019, 17:50 If you really think they got torqued to 500 ft lbs replace them all.
After a recent oil change and tire rotation I couldn't loosen the lugs even with a five foot cheater. This trick worked.
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
I used a similar method with a short ratchet and a hydraulic jack to pop loose a crank shaft bolt during a timing belt change on our sienna van. worked like a charm.
Dale..that’s looks like a SnapOn breaker bar, isn’t it? I am not sure I would try that with a cheapie...
- dalel
Amblerman, that was good thinking on your part.
What I want to accomplish before too long is new calipers. Haven't looked at the allen nuts that hold on the calipers (under the plastic cap.) I'm having reservations... getting the calipers off may be interesting. The brake hose I can soak with penetrating oil but I don't know if I can get that inside the sleeves that hold the caliper bolts. [shrug]
- Been thanked: 504 times
- I always add a tiny bit of wheel bearing grease (about one drop). This way next time it is easier. Have used this trick for 30 years.
- Don't scratch the paint work with your breaker bar!
- A guy on youtube used floor jack to undo the AXLE NUT and it work, see video below...
- amblerman
Thanks.. it was an act of desperation.
I had already tried:
1) wired HF electric impact gun (worked find on volvo.. not so much on toyota)
2) breaker bar + 2 ft of pipe.
3) breaker bar locked against frame and tried hitting starter to jolt it free.
No dice on all .
used jack + short 2x4 + ratchet handle worked.. may have been loosened up by 1-3 above though
-A
The caliper slide bolts are high quality stainless steel so they won’t stick like the Lug nuts.dalel wrote: 03 Sep 2019, 19:33 Amblerman, that was good thinking on your part.
But.....
The aftermarket ones are crappy steel and do corrode. They don’t usually stick in but’s they can impede proper caliper sliding, which kills your brakes.
Searching ‘caliper pin stick’ for a recent thread
https://www.matthewsvolvosite.com/forum ... iper+slide
- 1070 Views
Last post by zombielinux
- 26 Replies
- 11562 Views
- 4462 Views
Last post by NateTheGreat
- 484 Views
- 590 Views
Last post by jreed
