Did you know? 🤔
Loosen ANY lug nut
dalel
Year and Model: 1998 V70
Has thanked: 4 times
United States of America
dalel
Loosen ANY lug nut
Post by dalel » Tue Sep 03, 2019 5:20 pm
Loosen any lug nut by putting the jack underneath the lug wrench or breaker bar. Then jack up the lug wrench.
I tried this only after bending my original lug wrench AND bending a five foot cheater bar.
Dale L
Has thanked: 317 times
Been thanked: 982 times
Trinidad & Tobago
Re: Loosen ANY lug nut
Post by abscate » Tue Sep 03, 2019 5:50 pm
If you really think they got torqued to 500 ft lbs replace them all.
If they were just stuck with corrosion, they are fine. In that case, 30 seconds with a propane torch is a much nicer way to remove frozen fasteners.
Link To Volvo Glossary
dalel
dalel
Post by dalel » Tue Sep 03, 2019 6:31 pm
Good to see you...
After a recent oil change and tire rotation I couldn't loosen the lugs even with a five foot cheater. This trick worked.
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 35 times
amblerman
Post by amblerman » Tue Sep 03, 2019 7:19 pm
I used a similar method with a short ratchet and a hydraulic jack to pop loose a crank shaft bolt during a timing belt change on our sienna van. worked like a charm.
Trinidad & Tobago
Post by abscate » Tue Sep 03, 2019 7:22 pm
Dale..that’s looks like a SnapOn breaker bar, isn’t it? I am not sure I would try that with a cheapie...
dalel
dalel
Post by dalel » Tue Sep 03, 2019 7:26 pm
Abscate, it is a Pittsburg breaker bar from Harbor Freight. Now I'm getting worried.
dalel
dalel
Post by dalel » Tue Sep 03, 2019 7:33 pm
Amblerman, that was good thinking on your part.
What I want to accomplish before too long is new calipers. Haven't looked at the allen nuts that hold on the calipers (under the plastic cap.) I'm having reservations... getting the calipers off may be interesting. The brake hose I can soak with penetrating oil but I don't know if I can get that inside the sleeves that hold the caliper bolts. [shrug]
Has thanked: 0
Been thanked: 131 times
Post by cn90 » Tue Sep 03, 2019 7:40 pm
- I always add a tiny bit of wheel bearing grease (about one drop). This way next time it is easier. Have used this trick for 30 years.
- Don't scratch the paint work with your breaker bar!
- A guy on youtube used floor jack to undo the AXLE NUT and it work, see video below...
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Tue Sep 03, 2019 8:03 pm
Thanks.. it was an act of desperation.
I had already tried:
1) wired HF electric impact gun (worked find on volvo.. not so much on toyota)
2) breaker bar + 2 ft of pipe.
3) breaker bar locked against frame and tried hitting starter to jolt it free.
No dice on all .
used jack + short 2x4 + ratchet handle worked.. may have been loosened up by 1-3 above though
-A
Trinidad & Tobago
Post by abscate » Tue Sep 03, 2019 8:13 pm
The caliper slide bolts are high quality stainless steel so they won’t stick like the Lug nuts.
But.....
The aftermarket ones are crappy steel and do corrode. They don’t usually stick in but’s they can impede proper caliper sliding, which kills your brakes.
Searching ‘caliper pin stick’ for a recent thread
https://www.matthewsvolvosite.com/forum ... iper+slide
These users thanked the author abscate for the post:
dalel
