Did you know? 🤔
Rear swaybar 850 turbo.
rguzz
Year and Model: 1996 850 turbo
Has thanked: 0
Been thanked: 5 times
rguzz
Post by rguzz » Thu Sep 05, 2019 5:08 pm
Forgotten what people think on this subject. It's a wagon 850t with a tight suspension overall. Does handle a bit on the sloppy side when headed in to turns (feels like a boat, basically). Pros and cons to a rear sway bar, where to find one and what size should it be? How much is it likely to help with cornering?
Has thanked: 9 times
Been thanked: 149 times
Canada
Re: Rear swaybar 850 turbo.
Post by scot850 » Thu Sep 05, 2019 5:38 pm
I still find it strange that Volvos came with the rear anti-sway bar as an option. I understand there are the location points available on the rear axle for one. They were know to rust and break with age. I wonder if V/S70 parts would fit?
I know a regular AWD V/S70 front (like my R) anti-sway bar will fit a FWD. Rear though is totally different.
I wish you luck, but they do make a big difference at the back. On my 'R' I swapped the IPD HD front for a regular 'R' one and didn't notice much difference. The rear is still the IPD one re-finished with new bushes. Rear of car is nice and tight, but would replace with a regular one if I had to.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Has thanked: 72 times
Been thanked: 228 times
United States of America
Post by erikv11 » Thu Sep 05, 2019 6:04 pm
I would be surprised to see a T5 without a rear sway bar, did you look? Anyway it is entirely worth it, easy upgrade, try to grab one from any P80 FWD so equipped at the junk yard. If you can, get a thicker bar e.g. from a T5. However Volvo mixed and matched the bars a lot, you can't be sure what is on a given car. The best way to tell what a bar is, is by the paint splotches on it:
front sway bar part #s:
9173982 O.Dia 20 mm (marked red)
9173983 O.Dia 21 mm (marked yellow)
9173471 O.Dia 21.5 mm (marked yellow/blue)
rear sway bar part #s, probable O.Diameter:
9191459 (marked green) 19.5 mm
9191461 (marked yellow) 20 mm
9191462 (marked blue) 20.8 mm
9191494 (marked black) 21 mm
Or spend up and get bars from IPD, I've never gone that route though.
All FWD P80 cars use the same rear sway. AWD is different, no swapping there; is there even an AWD rear sway?
'96 855 NA, 140k
'98 S70 NA, 210k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 280k
'06 S60 R, 160k
Chuck W
Year and Model: 97 854 T5
Has thanked: 11 times
Been thanked: 27 times
Chuck W
Post by Chuck W » Fri Sep 06, 2019 7:32 am
The wife's '97 GLT didn't have a rear bar on it. The rear end always felt a bit "wollowy".
It has a set of 850R bars on it now.
tryingbe
Year and Model: None
Has thanked: 0
Been thanked: 22 times
tryingbe
Post by tryingbe » Fri Sep 06, 2019 1:23 pm
I had Konis and IPD rear sway bar and my 850 still feels like a boat.
Don't lose your sleep on it.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 230 times
Been thanked: 761 times
Trinidad & Tobago
Post by abscate » Fri Sep 06, 2019 6:46 pm
IPD heavy springs and a Sachs shocks all around....nice and tight
Link To Volvo Glossary
rguzz
Has thanked: 0
rguzz
Post by rguzz » Sat Sep 07, 2019 12:46 pm
Thanks. Yes, might not be a miraculous improvement adding a rear bar. Have a strut bar also ( I realize the controversy) but hoping the combination, strut bar and rear sway will make for an improvement. Not a huge investment if I find a used rear bar, or even go for a new one from Volvo. Haven't spent any $$ on the car in three whole months, so I think I will go for it. Thanks again for the input.
j-dawg
Year and Model: 1999 V70 T5
Has thanked: 0
Been thanked: 17 times
j-dawg
Post by j-dawg » Sat Sep 07, 2019 9:58 pm
Can't comment on the 850 chassis in particular, but generally, adding more anti-roll to one end of a car (independently of the other end) will tend to reduce grip, transferring load to the other end. Adding rear stiffness while leaving the front alone will increase the car's tendency to oversteer. These cars are tuned very conservatively, and the rear suspension is specifically designed to minimize oversteer, so adding rear anti-roll (and/or softening up the front end) will lively up handling at the limit, but it's hard to quantify.
For what it's worth, nobody seems to have ever said a harsh word about the IPD sway bars. They discontinued their "track spec" kit, which had a stiffer rear sway bar.
1999 V70 T5 5-SPD | ~270k mi | burns more oil than gasoline
