Did you know? 🤔
S60 Slow Acceleration
2001 - 2007 XC-70
- Pete -
Has thanked: 37 times
Been thanked: 57 times
United States of America
- Pete -
Re: S60 Slow Acceleration
Post by - Pete - » Mon Sep 09, 2019 8:46 pm
Boost in stock form should peak around 7-8 psi. I believe you are AWD & 2.5T, 2003 so that would be the low pressure turbo IIRC.
I'd sure plug in that scanner you have and see what it generates, then post whatever that is here. Chances are if it's timing it'll say something like P0014 (exhaust cam over advanced (Camshaft Position “B” – Timing Over -Advanced or System Performance (Bank 1)) Or P0012 for cam being over retarded etc..
Your engine should be dual VVT (VVT on intake cam as well as VVT on exhaust). This means you have a cam position sensor on EACH cam (it lives on the drivers side or "rear" of the engine) & if timing is off you will receive a code for one or the other cam or both being advance/retarded. You do NOT need Vida/DiCE to retrieve these codes. Vida/DiCE will tell you a heck of a lot more about the car and all it's modules/computers, but timing codes will show up with a generic scanner, thankfully.
Actually, in my experience the Volvo dealerships often do write in the engine bay when the timing belt etc. was replaced, and usually with a white paint marker. I have seen numerous very similar markings on P2's, and all are dated, mileage noted stating T-belt etc replaced on the cover for the ECM (it's the black box just left of your PS pump).
Also, checking timing isn't difficult. If you have tools & a means to get the front wheels off the ground + passenger front tire off it's not a bad task & this is a super frequently discussed topic here, ie answers tend to pop up pretty quick.
2001 V70XC 142k
2004 V70 AWD 134k
2004 V70R M66 142k
2004 XC70 278k
2006 XC70 155k Sold
Knullruffs
Year and Model: 2003 S60
Has thanked: 7 times
Been thanked: 0
Knullruffs
Post by Knullruffs » Thu Oct 03, 2019 6:41 pm
I was able to find some time to tinker with the car again and found out I can read the live timing on the scan-tool that I have. I'm not sure exactly what the ideal timing should be, but I am getting a reading of about 11deg at idle. The car was somewhat warm when I read it. Does that sound normal?
- Pete -
- Pete -
Post by - Pete - » Fri Oct 04, 2019 11:50 pm
Did you scan for codes? If timing is off you will definitely have a code.
Someone with more knowledge than I will have to take the 11* question.
2001 V70XC 142k
2004 V70 AWD 134k
2004 V70R M66 142k
2004 XC70 278k
2006 XC70 155k Sold
Year and Model: 2001 V70
Has thanked: 2 times
Been thanked: 28 times
Post by volvolugnut » Sat Oct 05, 2019 6:57 pm
I believe the 11 degrees at idle may be the ignition timing - not the valve timing. The moderate expense scan tool I have will give some basic live data including ignition timing, but not valve timing. Your reading sounds about right for ignition at idle.
If I am wrong and you indeed have a tool that shows valve timing, please excuse me.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 49 times
vtl
Post by vtl » Sat Oct 05, 2019 7:06 pm
No pull forward at idle is ATF. I have to step on the brakes all the time 'cause I roll faster then the rest. Fresh 1161540 + Lubegard HFM.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
