Did you know? 🤔
96 850 Turbo Starts but runs rough then dies. Backfires.
New2Volvo96
Year and Model: 1996 850 Turbo
Has thanked: 0
Been thanked: 0
United States of America
New2Volvo96
Post by New2Volvo96 » Sat Sep 07, 2019 9:32 pm
Hi all. I am posting this in hopes to help my father in law figure out what his problem is with his 96 Volvo 850 Turbo. I helped him replace the PCV system and he replaced the PNP switch but after it all got put back together it now will start but dies after about 5 seconds or less. If you keep on the throttle it will keep running albeit very rough, but it backfires and there is a strong gas smell. We tried checking the fuel pump relay and bypassed it didn't help and it sounds like the fuel pump is working though we haven't tested the fuel pressure yet. I haven't cleaned the MAF yet but I scanned for codes and found nothing and can't imagine a dirty MAF would cause this many problems. I'm hoping someone might have some insight as to what might be causing these issues. Possibly didn't get something put back together correct. Vacuum lines look good but it's hard to test them when it's running so bad. Any suggestions would be much appreciated. Also I should note that his car has something draining the battery so it only starts up when being jumped. Thanks guys!
Clemens
Has thanked: 95 times
Been thanked: 56 times
Austria
Clemens
Re: 96 850 Turbo Starts but runs rough then dies. Backfires.
Post by Clemens » Sun Sep 08, 2019 1:07 am
what about the intake manifold gasket? if there is a leak, it will run horrible.
are all the injectors seated and connected properly?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 363 times
Been thanked: 1113 times
Trinidad & Tobago
Post by abscate » Sun Sep 08, 2019 3:09 am
It’s really easy to pinch something between the manifold doing the PCV
Replace all the vacuum lines that you have no history on, at 20 years old +, they leak now.
Link To Volvo Glossary
rguzz
Year and Model: 1996 850 turbo
Has thanked: 0
Been thanked: 5 times
rguzz
Post by rguzz » Sun Sep 08, 2019 2:18 pm
Second the distinct possibility of an air leak at the intake manifold, ie the gasket. It can tear most easily in the upper right corner when replaced, I believe around the upper stud located there, but that is from memory. If it was running fine before taking on this job you will need to retrace your steps, unfortunately. Twice as fast the second time! Get a new gasket regardless. There are numerous step by step guides to help you if need be.
New2Volvo96
Has thanked: 0
Been thanked: 0
New2Volvo96
Post by New2Volvo96 » Mon Sep 09, 2019 5:17 pm
I was really hoping it wasn't the intake manifold but I had a sneaking suspicion it might not be on correctly or a bad gasket. I'll dive back in there and see what I can find. Thanks all. This forum is super helpful.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 172 times
bmdubya1198
Post by bmdubya1198 » Mon Sep 09, 2019 9:37 pm
I agree with everyone else, make sure your intake manifold gasket isn't leaking. Also check over all other vacuum lines.
It's unlikely given that this wasn't a problem before this work was done, but the car will struggle to run if the voltage is too low. Definitely do a parasitic draw test once this idle issue is knocked out.
2000 V70R Venetian Red/Charcoal M56 Swapped 198k
2003 S60 2.4T Silver/Black 116k
2007 XC90 V8 AWD Sport Titanium Grey/Black 173k
1991 944 Turbo Dark Green/Beige 174k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
Has thanked: 103 times
Been thanked: 312 times
Post by erikv11 » Mon Sep 09, 2019 10:05 pm
You're in good shape with all the comments IMHO. A peripheral comment -
... can't imagine a dirty MAF would cause this many problems. ...
If the MAF isn't visibly oily or grungy, cleaning it will almost never make any difference, not even a small one. Basically not worth spending for the cleaner. Do an unplug-the-MAF test first.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
